| Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG =- | Today's Posts | .: For Rent :. | Search |
| iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides. |
| | #4 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004 Location: Athens - Greece Age: 48
Member: 59935 Status: Offline Thanks Meter: 117 | Quote:
![]() BR baboom | |
| The Following 16 Users Say Thank You to baboom For This Useful Post: |
| | #6 (permalink) |
Member: 59935 Status: Offline Thanks Meter: 117 | Yes tested 100% . If you make red marked jumper you will have earsound , but headphones will not work !!! BR baboom |
| The Following 9 Users Say Thank You to baboom For This Useful Post: |
| | #8 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 574100 Status: Offline Thanks Meter: 159 | http://forum.gsmhosting.com/vbb/f456...lution-936581/ http://sunnychana.files.wordpress.co...k_assembly.jpg http://www.sparepartsformobiles.com/...one%20jack.jpg Last edited by abdeu77; 06-09-2010 at 14:36. Reason: Iphone 3g always in headphones mode |
| | #10 (permalink) |
| Junior Member Join Date: Jun 2010
Member: 1335728 Status: Offline Thanks Meter: 1 | i wrote this to another topic but i will ask to you too plaese help me Quote:Originally Posted by Burnt Cobba @ iku911 "Hello bossess. help me out from my problem....i have iPhone 3g when i use headphone then everything ok but when i remove headphone then no sound no ear sound no mic.. it still show connected headphone.. please help me out of this problem..." did u try to change the top flex? usually it will sort the problem. i hav the same problem,and i changed the flex but problem not solved,everthing is the same.headphones mode stuck.strange idea happens and it cofuses my mind that if i put my iphone 3g (fw 4.0) in the "refrigerator" about 1 minute it whill change mode to ringer and it has lock unlock sound or i can call someone but its only 1-2 minutes just like that.when iphone's temp goes to normal (from colder to warmer) it changes mode to headphones again. what can i do for it??? |
| | #11 (permalink) | |
![]() ![]() ![]() Did you ""refrigerator" boy" read post #6 ???? If so & if you have soldering gun at your home .... just try my solution ... Else give your phone for fixing to some1 with more experience ... ![]() BR | |
| The Following User Says Thank You to baboom For This Useful Post: |
| | #13 (permalink) | |
![]() OK, I will try to make it clear ... Open your phone & locate the marked part of the picture. Then use thin soldering gun & wire to connect the 2 pins without removing the IC (transistor) from PCB. If you go out of "headphone mode" you must replace this part with new one. ![]() Good luck. | |
| | #15 (permalink) | |
Member: 1335728 Status: Offline Thanks Meter: 1 | Quote:
thank you thank you thank you.... | |
| Bookmarks |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 05-21-2013 19:20 |
| blue Display in Nokia Cellphones | TheDon | Nokia Hardware & Hardware Repair | 0 | 10-29-1999 18:28 |
| New menu item in 5110 | GeoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-23-1999 20:24 |
| Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
