01-26-2010, 16:21 | #151 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1219539 Status: Offline Thanks Meter: 0 | If you're looking at the phone the right way up, with the connector on the top right hand side, the pin on the top row at the far right hand side has broken off. Can anyone tell me what this pin does on the LCD display? I think it may be the backlight to the LCD as the screen now has no backlight - however i'm not 100% sure the LCD is working correctly either so i'd like to know if anyone knows for sure what this pin does? Also, to fix the solution, could i crudely put a piece of solder onto the remains of the pin on the logic board, to make the connection to the plug on cable number 1? Or is ist a simple de-solder the whole connector and resolder a new one? [by the way - i wouldnt be the best solderer in the world!! ] Thanks in advance for any suggestions. Last edited by RDB1212; 01-26-2010 at 16:22. Reason: BTW It's a 3G Iphone. |
01-27-2010, 15:13 | #152 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 299902 Status: Offline Thanks Meter: 20 | l have the same problem but the bottom right row and its the second pin also l have no back light now lm not sure if your problem or my problem is the couse of the light problem or its some other problrm |
01-27-2010, 21:09 | #153 (permalink) |
Member: 1220688 Status: Offline Thanks Meter: 0 | 3g problem took phone to have home button replaced after which the phone came back and now does not power up unless attached to ac adapter and computer does not recognise ..i should say by power up on ac i mean it shows apple logo for ten seconds and then shuts off but can see a dimmed logo for a while ..phone was working perfectly until tech went inside ..tried the power and home button then but no luck ,tried the a method of flicking mute button 4 times and then power and home button press no luck. i can see lines like phone is trying to boot .. any help or ideas would be appreciated .. |
01-28-2010, 00:21 | #154 (permalink) |
Member: 1220645 Status: Offline Thanks Meter: 0 | running out of ideas how to recover my iphone.. the other day it said "no service" when i woke up, waited, nothing happened, finally decided to reset it.. and it's just been resetting ever since. took it to the genius bar also, they claim it's bricked (prolly because they saw my tmobile sim card in the phone instead of the at&t, and they realize it's bee jail broken). even took it apart to look around, and put it back together (sometimes that fixes minor issues with some electronics).. but same problem persists! would really like to backup my current data or get access to it somehow.. i'm considering getting a broken-screen iphone and maybe doing a transplant on the memory chip?? i know how to solder a little but the small size of the chip connects is a little daunting so i would rather not try (if it comes to that, does anyone have any advice??).. hmm, not even sure how to get the metal shield off the display side of the logic board so far, iTunes doesn't see the phone (unless i boot it to recovery mode).. is there a way to force a backup of the data in recovery mode perhaps?? plz help |
01-29-2010, 07:47 | #155 (permalink) |
Junior Member Join Date: Feb 2008
Member: 697232 Status: Offline Thanks Meter: 0 | Pls help! I accidentally droped my iphone 3g , now the backlight was gone! But I can still see the icons and use it. Only problem is the backlight ?! What could be the possible problem? I just recognized lately that when i shake my phone I heard sound in a specific area, as if there was diconnected part or cable ? pls help. |
01-29-2010, 14:56 | #157 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nokia Solutions
Member: 1062107 Status: Offline Thanks Meter: 544 | here' a big help for your search.... all the Chips Schematics Diagram Apple Iphone 3G and 3GS IC Parts Datasheets(Component Schematic Diagram and Info) For Hardware Pro's and Advance troubleshooter's Guide 3G 3GS SST SST25VF080B 1 MB SERIAL FLASH http://www.alldatasheet.com/datashee...T25VF080B.html Samsung ARM-based CPU (markings: 339S0036 ARM EMC567DB 819 8900B N182F0A3 0825 7511.101 ZPD8163Y) with DDR SDRAM Samsung http://datasheet.octopart.com/K4X1G1...eet-472067.pdf ST MICROELECTRONICS LIS331 DL ACCELEROMETER http://datasheetz.com/ST/13951/13951.html INFINEON SMP3i SMARTi POWER MANAGEMENT IC http://www.infineon.com/cms/en/produ...19ebec03f05327 Skyworks SKY77340 Power Amp. Module (824-915 MHz Power Amplifier Module Quad) http://www.datasheetpro.com/425257_d...datasheet.html Infineon PMB 6952 UMTS Transciever http://infineon.com/cms/en/product/c...12ab6ac4b80611 Triquint TQM676031 WCDMA/HSUPA power amp An integrated 3-V linear UMTS Band 1 power amplifier (PA), duplexer and transmit filter module, with output power detector. It supports HSUPA operation with transmission data-rates up to 10 Mbits/s. http://www.triquint.com/docs/o/TQM676021/tqm676021.pdf Triquint TQM666032 WCDMA/HSUPA power amp Similar like TQM676031, but for Band 2 operation. http://www.triquint.com/docs/o/TQM666022/tqm666022.pdf Triquint TQM616035 WCDMA/HSUPA power amp WCDMA/HSUPA PA-duplexer module for Band 5 and 6. datasheet unavailable Numonyx PF38F3050M0Y0CE 16 MB NOR Flash - 8 MB Pseudo-SRAM http://www.numonyx.com/Documents/Mar...ORwireless.pdf Infinieon Digital Baseband Processor NXP Power management http://people.openmoko.org/tony_tu/G...50633DS_02.pdf Linear Technology LTC4088-2 Battery charger/USB controller http://cds.linear.com/docs/Datasheet/40881fb.pdf Infineon PMB2525 Hammerhead II GPS http://www.datasheetdir.com/PMB2525+GPS Wolfson WM6180C Audio Codec http://www.wolfsonmicro.com/productListings/codecs Broadcom BCM5974 Touchscreen controller no datasheets available NATIONAL SEMICONDUCTOR LM2512AA DISPLAY INTERFACE http://www.national.com/ds/LM/LM2512A.pdf Toshiba TH58G6D1DTG80 8GB Flash (8GB model!) no datasheets available Marvell 88W8686 WiFi http://www.pdf-search-engine.com/88w8686-pdf.html CSR BlueCore6-ROM Bluetooth http://downloads.openmoko.org/develo...2520Issue1.pdf original link: http://forum.gsmhosting.com/vbb/showthread.php?t=906068 |
The Following 5 Users Say Thank You to =GsM_Angel= For This Useful Post: |
02-01-2010, 20:06 | #160 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1224858 Status: Offline Thanks Meter: 6 | Solder Pad on iphone sim card broken Hi, I've just been given a 3G iphone by a friend. He put the sim card tray in the wrong way round and broke some of the ***** pins. He therefore got a replacement part to solder on, but whilst removing the old connector he also managed to remove the solder pads from the PCB, so that there's now nothing to solder it to. Does anyone have any knowledge if there's somewhere else to pick up these connections on the logic board? Thanks |
02-01-2010, 20:13 | #161 (permalink) | |
Member: 1224858 Status: Offline Thanks Meter: 6 | Solder Pad on iphone sim card broken Quote: In the above image I am missing the pad for the blue connection. Does anyone know if this edited image refers to the iphone 3G as I can't find anywhere that looks like the embedded image to link it to... | |
02-01-2010, 20:36 | #162 (permalink) | |
Member: 1220688 Status: Offline Thanks Meter: 0 | Quote:
help please .....just a little help | |
02-01-2010, 21:22 | #163 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: CHILE
Member: 196727 Status: Offline Thanks Meter: 419 | Quote:
yes is iphone 3g is at backside under radiation graphite sheet br nafg | |
02-02-2010, 16:57 | #164 (permalink) | |
Member: 1224858 Status: Offline Thanks Meter: 6 | Quote:
Thanks for confirming it is the 3G model of the phone. I have removed the graphite sheet and now am faced with a PCB which looks identical to the one shown here http://s2.guide-images.ifixit.com/ig...1YVQh2IW.large . I would be very grateful if someone could show the correlation between this image and the previous one from nafg. If someone could highlight where the various colour-coded points connect to from the original image... | |
02-02-2010, 18:14 | #165 (permalink) | |
hi solution sim thank for pic br nafg | |
The Following 3 Users Say Thank You to nafg For This Useful Post: |
iPhone 3G S Diagram Here | delower10 | iPhone, iPad, iPod Hardware Repair | 11 | 12-27-2010 14:57 |
IPhone 3g broken motherboard no service | Farntet | iPhone 4 / iPhone 4S | 4 | 11-25-2010 11:51 |
iphone 3G MotherBoard Diagram------By {{{Rasel--Wingstel--Bangladesh}}} | Wingstel | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-27-2010 12:26 |
iPhone 3G S Motherboard Diagram by parts | Zulea II | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 11-23-2009 08:03 |
