12-12-2010, 20:26 | #1 (permalink) |
Insane Poster Join Date: Oct 2009 Location: Lithuania
Member: 1147787 Status: Offline Thanks Meter: 12 | iphone 3g verry poor signal I tried even restore .And when open iphone the signal gets little stronger.Maby one of fuse broken ? |
12-14-2010, 11:41 | #3 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Earth and around
Member: 1442842 Status: Offline Thanks Meter: 103 | First check if these Coil present or any line is broken if not you can bridge this important is also the connection from dock to Bezel/housing lock to the dock. There are two rings. Both must be connected on top of the bezel holder, not under! Otherwise you have no good connection to the bezel. The bezel works like a antenna Holder on bezel |
12-14-2010, 14:55 | #4 (permalink) |
Member: 1147787 Status: Offline Thanks Meter: 12 | Hello ,the bezel is fine ,because when i put other iphone mainboard the signal is verry good.I think that this item is fault because when i pushed him stronger the signal has became litle bit stronger .But still no edge and signal strenght is almoust always at 2 .What if i push that component with hot iron ,maby he will stick better with mainboard ? If not i have bad mainboard is it posible to switch it ? Last edited by tomuxzz; 12-14-2010 at 15:04. |
The Following User Says Thank You to tomuxzz For This Useful Post: |
12-15-2010, 11:03 | #5 (permalink) |
Member: 1442842 Status: Offline Thanks Meter: 103 | Ok.. this little Part is a coil. This all is HF technik. Not easy to understand.. I had some phones too, with this effect. I try'd to change this coil, but it changed nothing. Sometimes i lost this part when i solder this out, he flips away, and never found.. :-) So i make a bridge with solder tin, and voila, i have a strong signal. You can try this, but carefully, when this not works, you can place this coil back. |
12-15-2010, 22:07 | #6 (permalink) | |
Member: 1147787 Status: Offline Thanks Meter: 12 | Quote:
12-23-2010, 04:45 | #8 (permalink) |
Freak Poster Join Date: Apr 2007 Location: UIO - EC Age: 37
Member: 483230 Status: Offline Thanks Meter: 25 | Maybe i'm in the wrong post but, what happen if this same problem appears after UNLOCKING (you know... downgrading the baseband from 5.14.02 to 5.13.04). Can somebody tell me what could it be??? |
12-31-2010, 18:45 | #10 (permalink) | |
Member: 483230 Status: Offline Thanks Meter: 25 | Quote:
Now it's solved just by making a short between the antenna and the PCB... And let me tell you... iPad baseband (6.15) works perfect.... Greetings Community | |
01-08-2011, 01:02 | #11 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1487836 Status: Offline Thanks Meter: 1 | Hi there I have the same problem is there any better pictures of the bezel / and the connector please, where on phone are they situated? (really excited as this seems to be the answer i've been looking for) but need to now if these fixes have worked and what exactly im looking for. Do I need to use special wire to bridge the gap? Please help, I feel like I've been trapped in the X-Files for the iphone (the truth is out there) ....somewhere. Thanks Rich |
The Following User Says Thank You to rich_purser For This Useful Post: |
01-27-2011, 21:10 | #12 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1431277 Status: Offline Thanks Meter: 1 | Hi...I was an idiot when I opened my iphone 3G for the first time , and cracked the corner of the pcb where the antenna connector is. So now I have a very weak signal as well. Sounds like the same problem that DJ-JaaM had? Could someone (maybe JaaM?) tell me how to short this connection? Thanks! |
The Following User Says Thank You to w14 For This Useful Post: |
03-12-2011, 20:55 | #13 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1535264 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Hi...... I have the same problem and i dont know how i can resolve....i search in internet for 4 months witn no results....please you can tell me if you could sove your problem.....thanks and sorry for my english .... im from south america |
05-04-2011, 20:04 | #14 (permalink) |
Crazy Poster Join Date: Sep 2007 Location: LAHORE Age: 35
Member: 584884 Status: Offline Thanks Meter: 7 | hey bro this is hardwear problam only change antina switch on the motherbord problam is clear |
The Following User Says Thank You to samar_prince For This Useful Post: |
6110 no signal | amana24 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-22-2001 11:41 |
5110 v.5.24 bad signal | mudboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 10-17-2001 01:55 |
Signal up and down | Moc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-29-2001 10:57 |
how do you solve no signal - 5110? | philipal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-29-2001 03:27 |
5110 drop no signal!!! | eureka8888 | Nokia Hardware & Hardware Repair | 0 | 09-16-2001 16:15 |
