Iphone 3g Weak signal I have this phone but don't know why the signal are very weak? most of the time with all the sims the signal point stays at one reason why several times calls cuts out. what is the problem with the phone? thank you |
try to restore it via itunes.if software issue,then hope fully solve after restore,but u have to unlock it again.this is so easy.so restore it and post result.if u dont know how to restore.let u link.luck http://www.youtube.com/watch?v=9WU22SR-PVM |
tried it but signal are very weak |
In network options enable 3g and check it Disable 3g and check it if not solve Check hardware net work an****a cinnector |
change antena switch............ |
http://www.mobilehq.com.au/products/...nna%20flex.jpg If that doesn't work, check your logic board. It might have a crack on the logic board. This worked for me. How I recovered my iPhone's lost GSM signal! |
