09-24-2012, 08:21 | #1 (permalink) |
No Life Poster Join Date: Mar 2000 Location: next to you ; ) Age: 54
Member: 1133 Status: Offline Thanks Meter: 38 | Iphone 3Gs Charging problem, not charging module problem. I have a 3Gs when connect to the charging module, it does not detect the phone. I have replaced the charging module, the battery is good so it's a board problem. Wites gave a tutorial on shorting Q4 & Q5 (bypass) but this board is very different. It does not have Q4 and Q5. Most schematics avaliable is based on Q4 & Q5 model. Hope you can help. Thanks |
09-25-2012, 09:34 | #3 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Wikon, Switzerland
Member: 1012778 Status: Offline Thanks Meter: 245 | short question: what happens when you connect the Charger without battery and you measure on the battery + and -. Is there any voltage? Was the phone dropped? Used a "China-Charger" ? |
The Following User Says Thank You to kostelectronics For This Useful Post: |
09-25-2012, 18:09 | #6 (permalink) | |
Member: 1133 Status: Offline Thanks Meter: 38 | Quote:
It is not caused by china charger. It was a result of changing a low quality back housing that makes the phone very difficult to power on. (When board connected to the battery, the voltage drops - board shorting) After many attempts, I finally found a good quality housing, and not this charging problem happens. | |
