Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-20-2012, 09:52   #1 (permalink)
Member: 675986
iPhone 3GS no backlight coil is OK
Hi all,
I have a dropped 3GS phone with no backlight when tested with good working LCD screens. The 6R8 coil measured 0.8 Ohm so it must still be OK.
Pin 1 of 109 IC to pin 3 on LCD connector is still OK (0 Ohm).
No water damage to the iPhone.
What else should I check?
Thanks.
Old 07-20-2012, 10:04   #2 (permalink)
Member: 675986
Also, how else do you confirm that the 6R8 coil is still OK?
Correction: It was pin 6 of the 109 IC to pin 3 on LCD connector is still OK (0 Ohm)
Thanks.
Old 07-20-2012, 12:08   #3 (permalink)
Member: 1757226
Just follow the masters guide: http://forum.gsmhosting.com/vbb/f631...cture-1409330/
post number 9. Continuity on the coil says nothing about whether is works well.
Follow post nr 9.
The Following User Says Thank You to Reinsaddict For This Useful Post:
Old 07-20-2012, 13:04   #4 (permalink)
Member: 675986
Thanks,
This one got me stumped. There is 4V on pin 3 of the LCD connector. This means that the 6R8 coil and the 109B IC are working as they should but still no backlight
Help anyone?
Old 07-20-2012, 13:19   #5 (permalink)
Member: 1085383
check this solution..check if you not have missing components .. thx Wites for picture..
The Following 2 Users Say Thank You to MeiTeS For This Useful Post:
Old 07-20-2012, 14:29   #6 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
Originally Posted by wildwild View Post
Thanks,
Help anyone?
This is good but 4V can be even if coil is bad so when lcd is connected it must generate around 12V to 16V understand.
The Following User Says Thank You to Wites OM Tesla For This Useful Post:
Old 07-20-2012, 14:49   #7 (permalink)
Member: 675986
Thanks Wites,
I had a look at the 3GS schematic diagram and still could not work out why it would not work. If the coil is bad/open circuit then there should not be any voltage at pin 3 of LCD connector at all. The 4V was when the LCD was not connected.
One other possible fault is the Power MIC chip not driving the Gate (pin 5) of the MOSFET in 109B IC properly.
PS: I can understand electronics pretty well
Old 07-20-2012, 14:54   #8 (permalink)
Member: 675986
Already checked and all components are OK.
Old 07-20-2012, 14:56   #9 (permalink)
Member: 675986
Hi Wites,
What should the voltage on pin 4 (Gate of the MOSFET) of the 109B IC be without the LCD connected?
Old 07-20-2012, 15:46   #10 (permalink)
Member: 1427645
Sonork: sohail----
every thing is ok then go for software ur problem solf
Old 07-20-2012, 15:52   #11 (permalink)
Member: 675986
Restored already. Same problem.
Old 07-20-2012, 16:38   #12 (permalink)
Moderator
Member: 1017374
If coil is open no voltage if coil is short inside 4V if coil is good 4V without lcd.
Man did you replace some component or you chk only under microscope?
Old 07-21-2012, 00:34   #13 (permalink)
Member: 675986
I took measurements and looked under a microscope. It could be a shorted coil. I will replace the coil and see if it was the cause.
Old 07-21-2012, 05:23   #14 (permalink)
Member: 675986
UPDATE: I replaced the 6R8 Coil from an old spares and to my surprise the brightness came on
So it must have been partially shorted (measured 0.6 Ohm instead of 0.8 Ohm on my multimeter)
BIG THANK YOU to Wites. You are a LEGEND .
Now I have another problem with another 3GS. It only accepts charge through USB but not through the dock or power adapter. Already tried mainboard in other good housings but same problem.
Thanks all.
Old 07-21-2012, 10:59   #15 (permalink)
Member: 1757226
Thanks all.
Yep the coil is a strange thing . Told you continuity doesnt mean its working. Glad you fixed it.
For charging look at other Wites fixes in his sticky topic. Truly he is a legend, THE legend.
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 12 09-02-2012 19:17
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? telefonman Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 02-13-2000 19:06
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-26-1999 14:31
Page generated in 0.53250 seconds with 12 queries
