iphone 3gs not charging ! Hi to all ! Could someone advise me on a iphone 3gs ( 16gig ) it has the red dots indicating water damage however it did work normally and charge ok until one day I plugged the charger in and no charge ! I have had the charging block changed but still no charge ! Any soultios for this or How can I improvise a charge on the battery so that I can retrieve some data and photos from the iphone ? I also have a iphone 3g ( 8 gig ) it was a customers iphone and he had installed cydia and upgraded the baseband to the ipad one.. Problem is now when I try to install a firmware ( custom 4.2.1 using snowbreeze ) the iphone now has no wifi and no baseband is highlighted in settings ! Thank you mercury |
1 Attachment(s) Hi, Check the charging coil for voltage, also the centre capacitor, it needs to show battery voltage. |
is there a quck fix to put some life in the battery ? Enough time for me to backup my photos etc ? That's of course if the charging / data block is ok ! mercury |
check the fuse/resistor, its green near to antenna, try another battery. |
As we look at the battery with the pins at the bottm right ..which of the 4 pins is + and - and can I modify say a nokia 3.7 v charger and give it a quick charge ? mercury |
1 Attachment(s) Quote:
Repair ? Quote:
Hi, Are you UK based ? Do you repair iphones ( my 3gs ) ? mercury |
3gs charging ! Ok just an update .. I manged to charge my iphone 3gs battery ( by using an old Nokia charger and removing the battery ) Ok so my phone starts up and itunes recognises my phone..so the data cable works ..problem is that the phone will not Charge ! Charging block ? ic's etc ? mercury |
mercury |
thank you to this references |
i have iphone 3g a1241 16 gb i have serviced the mobile , battery is also replaced (original) but charge drains very fast back up only few hours but its normal not heatining or any other problem unit is normal is this pcb complaint r component complaint capacitor resistor didode or any coil ,, plz helpme thx in adv [email protected] |
