Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-27-2012, 14:37   #1 (permalink)
mercury's Avatar
Member: 4145
iphone 3gs not charging !
Hi to all !
Could someone advise me on a iphone 3gs ( 16gig ) it has the red dots indicating water damage however it did work normally and charge ok until one day I plugged the charger in and no charge ! I have had the charging block changed but still no charge ! Any soultios for this or How can I improvise a charge on the battery so that I can retrieve some data and photos from the iphone ?
I also have a iphone 3g ( 8 gig ) it was a customers iphone and he had installed cydia and upgraded the baseband to the ipad one.. Problem is now when I try to install a firmware ( custom 4.2.1 using snowbreeze ) the iphone now has no wifi and no baseband is highlighted in settings !
Thank you
mercury
Old 07-27-2012, 16:01   #2 (permalink)
dog68's Avatar
Member: 1728699
Hi, Check the charging coil for voltage, also the centre capacitor, it needs to show battery voltage.
Old 07-27-2012, 16:37   #3 (permalink)
mercury's Avatar
Member: 4145
Thank you .... It may be slightly out of my limited knowledge of electrical capabillities !
is there a quck fix to put some life in the battery ? Enough time for me to backup my photos etc ? That's of course if the charging / data block is ok !
mercury
Old 07-27-2012, 17:57   #4 (permalink)
dog68's Avatar
Member: 1728699
check the fuse/resistor, its green near to antenna, try another battery.
Old 07-27-2012, 21:01   #5 (permalink)
mercury's Avatar
Member: 4145
Ok I have took apart my iphone and removed battery ( just ordered a new one and connnector block from **** )
As we look at the battery with the pins at the bottm right ..which of the 4 pins is + and - and can I modify say a nokia 3.7 v charger and give it a quick charge ?
mercury
Old 07-29-2012, 21:05   #6 (permalink)
7ope's Avatar
Member: 1315205
mercury
yes you can conect your nokia charger directly to the battery
Old 07-30-2012, 16:59   #7 (permalink)
noobfix's Avatar
Member: 1738165
iPhone 3GS 'Not Charging' from USB wire Solution power IC chip
The Following 2 Users Say Thank You to noobfix For This Useful Post:
Old 07-30-2012, 21:58   #8 (permalink)
mercury's Avatar
Member: 4145
Thank you ...worked a treat !
Old 07-30-2012, 22:03   #9 (permalink)
mercury's Avatar
Member: 4145
Repair ?
Hi, Are you UK based ? Do you repair iphones ( my 3gs ) ?
mercury
Old 07-31-2012, 18:42   #10 (permalink)
mercury's Avatar
Member: 4145
3gs charging !
Ok just an update .. I manged to charge my iphone 3gs battery ( by using an old Nokia charger and removing the battery )
Ok so my phone starts up and itunes recognises my phone..so the data cable works ..problem is that the phone will not Charge ! Charging block ? ic's etc ?
mercury
Old 08-01-2012, 00:45   #11 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
mercury
Friend why not send in good service in UK?contact Hobson here on forum he is from Ireland one of best master.
Old 08-01-2012, 11:39   #12 (permalink)
mercury's Avatar
Member: 4145
Thank you. I have sent Hobson a message !
mercury
Old 04-10-2013, 01:59   #13 (permalink)
Member: 1738164
Sonork: 02582f199295e049a384ace29
thank you
to this references
Old 04-16-2013, 12:49   #14 (permalink)
Member: 1066806
Sonork: 10203
i have iphone 3g a1241 16 gb i have serviced the mobile , battery is also replaced (original)
but charge drains very fast back up only few hours but its normal not heatining or any other problem unit is normal is this pcb complaint r component complaint capacitor resistor didode or any coil ,,
plz helpme thx in adv bsurendar801@gmail.com
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
hope it is not too comercial aleksj Wanted Products 0 06-12-2000 13:22
Nokia 5110 - "SIMcard not accepted". Kond Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 03-02-2000 21:46
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 01-26-2000 13:31
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.39286 seconds with 12 queries
