yes just use a wire and link them |
that was harder than it sounded. still no sync or charge |
http://img443.imageshack.us/img443/7...ingproblem.jpg This SOLUTION been posted by other member, I haven personally tested because I never had the need to. This is serious hardware work and you must at your own risk. |
just to make sure, i tried it powered on and plugged in to computer to check for sync or charge while making sure i had an absolutly strong jumper connection and while nothing happened, when i pulled the probe out of the vase it shorted for a tiny second against metal bezel (ground) and the computer gave me a notice i was drawing too much power. so its very obvious that juice is flowing at least up until that point. |
and that pic is a 3gs correct? also is there a proper way to remove the aluminum that covers up that area of the phone? |
to remove the shield, you just need some sort of a small flat head screw driver or a guitar spectrum. the above picture is correct for 3Gs USB docking filter, if you cannot find the replacement filters then do the link as shown the above picture. Good luck!! |
Yes, I suggested to replaced the battery before getting deep into hardware It's much safer also for a nubie. |
there's much reason to believe its not the battery. if after reading it in full, if you still feel the same way about the battery please let me know. what do the docking filters do? |
The filter protect the phone for wrong polarity and over-voltage and mainly filter interference and supress voltage spicks(also sometimes cause by statick energy diference between units) cause by other devaices when you plug into the phone(like charger, computer,back batery etc etc) Yes the BATTERY also has a over-voltage and over-current and smart power managment circut built in So i would try another battery as a precaucion |
that's all good luckhttp://img96.imageshack.us/img96/775...phonefront.jpg |
i'm no stranger to soldering circuit boards, or swapping out known defective components on such things as audio amplifier boards, or fixing electrical connections large and small. no offense taken though! :D i just need guidance as where to concentrate while looking for a solution or bad component. i am very appreciative for any and all help. especially thanx to alexlaboratory. you've been working hard to help me. thank you again! |
the idea of bypassing a fuse doesn't seem as bad to me as bypassing the filters. that seems more of a last resort. @ mphone: yes, i checked the fuses already. i am thinking of checking the one on the battery itself too? waste of time?? (if you read my original post you will see it does "un officially trickle charge", which tells me current is reaching it, but is mostly weak from bad connection or some kind of incurred resistance somewhere) |
Your reasoning is correct, and the filters could be the answer..........but please check battery and change if possible. |
thanks |
i will obtain the battery which will probly take a few days, then report back here wether it worked or not. if not, i will ask for help with the filters. was that diagram for bypassing the filters by some means? if it turns out to be one of the ICs, those require a special equipment to change, correct? |
