Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-10-2012, 08:05   #1 (permalink)
Member: 1070846
Thanks Meter: 4
iphone 4 always restart
iphone 4 always restart in every 2 or 1 minutes help
Old 11-10-2012, 08:19   #2 (permalink)
Member: 1595839
Sonork: 1627697
Thanks Meter: 13
update firmware with help of itune use lastest itune
Old 11-10-2012, 09:05   #3 (permalink)
Member: 1070846
Thanks Meter: 4
ive already update to latest version bro but still dsame..
Old 11-10-2012, 09:14   #4 (permalink)
Member: 1012778
Thanks Meter: 245
Water damage? Check the Gas-Gauge signal from Battery, it must be 2.5V
The Following User Says Thank You to kostelectronics For This Useful Post:
Old 11-10-2012, 09:19   #5 (permalink)
Member: 1070846
Thanks Meter: 4
its not water damage bro,i already check gas gauge and its ok,battery lines is all ok..latest version 6.0.1 but its still dsame problem
Old 11-10-2012, 22:54   #6 (permalink)
dog68's Avatar
Member: 1728699
Thanks Meter: 212
Check Resistors
Check these two Resistors:
Old 11-11-2012, 09:53   #7 (permalink)
Member: 1070846
Thanks Meter: 4
still thesame bro,maybe this is U60 problem,because the sounds are not good..is it possible the U60 can make the restart problem?ill try to replace this and post result
Old 11-11-2012, 10:02   #8 (permalink)
dog68's Avatar
Member: 1728699
Thanks Meter: 212
Check this first, thanks goes to kostelelectronics
Old 11-11-2012, 15:44   #9 (permalink)
Member: 1070846
Thanks Meter: 4
i alredi do that jumper but still nothing,replace also U60 still thesame but the sounds are good now..only really restart problem..
Old 11-12-2012, 10:48   #10 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,594
Remove dock flex see if work without it then replace it might be short and cause this faults,check also on board dock connector if clean not broken some part of this connector if so you might misplace it and cause such fault.
The Following User Says Thank You to Wites OM Tesla For This Useful Post:
Old 11-13-2012, 17:33   #11 (permalink)
Member: 1070846
Thanks Meter: 4
mr wites i already done replacing dock ang charging flex,still the problem is not solved..any other ideas?thanks
Old 11-13-2012, 17:50   #12 (permalink)
Member: 1017374
Thanks Meter: 2,594
Try other battery for testing.
Is there some other fault like no imei always searching etc?
Because restarting can be if battery ways are damaged or if BB CPU have crack in balls after dropped,you say that you chk NTC and Gas Gauge make other reading chk resistance to GND of NTC and Gas Gauge at diode testing hold red to GND and with black chk if some not show readings it would mean it is broken.
Old 11-14-2012, 08:37   #13 (permalink)
Member: 1070846
Thanks Meter: 4
all is ok,wifi,imei,sounds,mic charging all,exept the restart problem i will check again the 1 you said earlier thanks
Old 12-05-2012, 18:53   #14 (permalink)
Member: 166520
Thanks Meter: 2
did you try to turn in DFU mode and run Redsnow then fix recovery mode?
Page generated in 0.21132 seconds with 9 queries
