Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-07-2011, 09:13   #1 (permalink)
Member: 1012778
iPhone 4 Camera solution and measure points
this solution is tested 100%
Front camera not working (water damage)
The Following 4 Users Say Thank You to kostelectronics For This Useful Post:
Old 08-09-2011, 08:05   #2 (permalink)
Member: 1237630
jumper to where? thanks
Old 08-09-2011, 14:06   #3 (permalink)
Member: 1012778
in the rectangle is normally a 01005 SMD-jumper. you can make a jumpwire. Works 100%
Old 08-09-2011, 15:33   #4 (permalink)
Member: 1216441
please explain me for detail...this is for front or back camera?
i have iphone 4 with camera cannot open, so u can give me some advice?
Old 08-10-2011, 10:19   #5 (permalink)
Member: 1012778
pls read carefully! it's for the front camera!
and there is a small part that fell off sometimes, you have to bridge with a jumper, that's all! i can't more detailed!
Old 08-10-2011, 17:02   #6 (permalink)
Member: 1362896
%100 working solution.
It saved 2 iPhone which had this problem already.
Old 08-10-2011, 18:20   #7 (permalink)
tigran80's Avatar
Member: 195651
part is gone on the phone I have. Unfortunately cannot make jumper, one pad is missing.
Is there any solution to make jumper?
Old 08-11-2011, 22:30   #8 (permalink)
Member: 1586345
thanks a lot buddy that was a really nice worked like magic,,,
Old 08-12-2011, 20:29   #9 (permalink)
Member: 1012778
@tigran80: wait me, i must make a photo. no problem when the pads are gone! i give my best!
Old 08-12-2011, 20:31   #10 (permalink)
tigran80's Avatar
Member: 195651
thanks man. I`ve already fixed it.
Old 08-13-2011, 01:59   #11 (permalink)
nafg's Avatar
Member: 196727
any need solution iphone 4 camera 5mp and flash and front camera????ç
br
nafg
The Following User Says Thank You to nafg For This Useful Post:
Old 08-13-2011, 07:17   #12 (permalink)
Member: 1012778
@nafg: water damage? pls check this measure points first:
iPhone 4 Camera (back) measure points
when LED-Flash don't work, check the camera conector well or change the MAX8834 under the metal shield near the battery.
The Following User Says Thank You to kostelectronics For This Useful Post:
Old 08-13-2011, 09:35   #13 (permalink)
Member: 1477098
My iphone 4 front camera still has that componentbut not work at all. Another solution please? Thanks
Old 09-10-2011, 04:14   #14 (permalink)
Member: 1652069
help
Hi, could you help me please?
i am having this issue with my iphone4... i tried soldering with standard solder, this 'pad', and camera got working for some seconds.. then i tried to put the solder more carefully and from then on i cannot make it work. besides, the solder keeps getting off the board.
i am not an expert in electronics.. only have a common soldering iron and solder, how can i make a successful fix ? can you give me some help please?
regards
Old 09-10-2011, 10:28   #15 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
regards
You can solder a jumper with a thin wire from some damaged speaker of some phone.
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.37797 seconds with 12 queries
