06-12-2012, 00:54 | #17 (permalink) |
Freak Poster Join Date: Jul 2011
Member: 1615254 Status: Offline Thanks Meter: 53 | Problem is caused by light leaking from LCD, not from light above. The tape trick will work, however you must remove all previous glue. Ideally you should use a foam surround like the picture on page 1. The 4S comes with one of these standard now, which only further proves this theory. |
06-12-2012, 04:39 | #18 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Toronto, Canada
Member: 1430995 Status: Offline Sonork: 100.1613203 Thanks Meter: 312 | Just use electric tape. Cut 4 small strips and put them around proximity sensor. Do not cover the sensor just around it. I will try to post pictures. 1000% work. Tested by me.. |
03-14-2013, 23:22 | #19 (permalink) |
No Life Poster Join Date: Feb 2002 Location: germany Age: 49
Member: 9584 Status: Offline Thanks Meter: 31 | i ve lots of iphone 4 with power button problem and i tried many different power flex from different suppliers. after i am changing the flex i ve problem with proximity sensor . i tried every solution with tape, cd marker etc i also took the tape from the old powerflex. but non of them working. i took the power button from a working phone everything is ok. could somebody help me |
03-27-2013, 07:02 | #20 (permalink) |
Freak Poster Join Date: Jan 2005 Location: geelong
Member: 106020 Status: Offline Thanks Meter: 5 | ive tried all of the obove, still same problem, iphone 4 running ios 6.1.2 1- changed lens from white to black- no good 2- changed sensor cable twice - no go 3- changed mid frame - no go 4- fitted black tape - no go and still nothing? ive never had this problem changing the lens before and i have done thousands. is there any solution for this as i need to fix. Thanks Bill |
03-27-2013, 12:03 | #21 (permalink) |
Crazy Poster Join Date: Jul 2012 Location: West Side
Member: 1780806 Status: Offline Thanks Meter: 6 | We should find a way to test this sensor in having a call while he's disassembled because it's painful to teardown again and again... The last i4/4s i've repaired make me sick with this proximity sensor. Would the sticker sold on our famous auction shop fix every time this breakdown ? |
03-27-2013, 23:51 | #23 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1481974 Status: Offline Thanks Meter: 42 | My solution always works. What I do is use some frosted tape such as this: http://3.bp.********.com/-CIPH5nxoIe...magic+tape.jpg Cut a little piece of tape to cover both the holes for the proximity sensor. Once covered, used a black marker such as a sharpie to color the tape. Put back together. Test with voice memos and you're good |
01-12-2016, 16:31 | #26 (permalink) |
Junior Member Join Date: Jun 2014 Location: DG Khan Pakistan
Member: 2197181 Status: Offline Thanks Meter: 0 | My iphone4 has problem in the light sensor . when i change by another motherboard all (proximity sensor) is Ok & take this motherboard in another case, sensor is OK . but i change flat cable sensor is not Ok!!! please help me. best regards |
03-24-2017, 16:44 | #27 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1349375 Status: Offline Thanks Meter: 8 | Hi, all (SOLVED) I have the same problem after changing lcd of iphone 4, tried everything, change new lcd ,new power flex with sensor, square adhesive, put doble uv filter, put black tape on backlight upper part so that no light will leak from back light to sensor, same problem, then i give up and convince owner to use the phone like this without turning off the lcd while on call or audio recorder, i want to try to reset but will take time owner in a hurry so as last try i tried to: !!!!!RESET ALL NETWORK SETTING!!!!!! And the phone works then charged the customer a little higher because i solve also the sensor problem I hope this will help somebody |
03-24-2017, 16:50 | #28 (permalink) |
No Life Poster Join Date: Jun 2003 Location: KA , Deutschland Age: 47
Member: 32168 Status: Offline Thanks Meter: 183 | This solution is very strange with network settings....what is the involving of network settings in this ? i am sure that you made it before this reset and works but you checked only after reset...i had lots of iphones with this problem and it was none that i can`t fix ...and without this reset regards |
03-29-2017, 14:12 | #29 (permalink) | |
Member: 1349375 Status: Offline Thanks Meter: 8 | Yes i know its strange, as i had explained i already check and tried all and its not working i called and convince the customer to use it like this because hes in hurry, while waiting for customer i want to try other solution as suggested and done by genius in apple, which is to setup as new phone , reset phone, and reset network setting, i dont have enough time to do a complete reset so i tried the easiest and fastest which is " RESET NETWORK SETTING " and the sensor works just in time before the customer arrived and we are both happy that i solve all problems. I think the sensor calibration is somehow disturb by disconnecting and testing other sensor, and by reseting network setting it recalibrate the sensor to correct value and it works, Thats why since this is easy and fast way to check or correct sensor problem give it a try and leave comments here if it work also for you so that we can help other with same problem, and avoid painfull assembly and disassembly just to check this sensor. Quote:
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
