Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-10-2012, 17:53   #1 (permalink)
Member: 1488173
Thanks Meter: 194
Unhappy Iphone 4 No imei
Hello friends, i need help to solve this issue, i know here exists many people with good potential to repair this phones (Mr. Wites, etc...etc), i am having problems with an iphone 4, when i try to restore itunes give me error (-1) and after replace battery the same problem.
I think there is a problem with voltage that needs the baseband ic, maybe somebody can tell me where to start.
thanks !!
Old 07-10-2012, 18:12   #2 (permalink)
Member: 1488173
Thanks Meter: 194
i donīt know if wifi is dead too because the iphone is not activated, after restore with custom and ireb, the phone turn on but is needed the activation and the phone does not recognize any sim card.
Old 07-10-2012, 18:56   #3 (permalink)
roro_manool's Avatar
Member: 192974
Sonork: 100.1627605
Thanks Meter: 495
try to update the phone normally by itunes untill you get error 1 then after that make a custom ios 5.1.1 by redsn0w without baseband update after that if your phone have a software fault it will be repair , if not working then it is hardware you need to change or reball baseband ic
Old 07-10-2012, 19:08   #4 (permalink)
dog68's Avatar
Member: 1728699
Thanks Meter: 212
Check baseband volts, hope this helps a bit.
Old 07-10-2012, 19:47   #5 (permalink)
Member: 1488173
Thanks Meter: 194
thanks !!
Already did that and the phone turn on but no imei
Old 07-10-2012, 19:50   #6 (permalink)
Member: 1488173
Thanks Meter: 194
thanks !!
Hello, thanks for sharing picture but, what voltage values exists in that points?
Old 08-25-2012, 07:05   #7 (permalink)
Member: 1439005
Sonork: alexz702
Thanks Meter: 11
i don't have voltage in one of the l8 l6 l3 but i do get on the rest
Old 08-25-2012, 11:37   #8 (permalink)
Member: 1770097
Thanks Meter: 17
L6 and L8 connects to battery so you should get battery voltage on both sides.
If only on 1 side, replace it.
Ohm out the coil and make sure they beep.
Old 08-25-2012, 15:00   #9 (permalink)
Member: 1159444
Thanks Meter: 7
i got bit different Problem on iPhone 4.
Restore with iTunes works fine, no Error, than Phone boot up to activation Screen and
Shows "searching" without Sim Card.
Wifi, BT, Modem Firmware are okay, bit time before it works normaly after restore and
i couldt activate it in usual way, Network came and after view Minutes Network gone.
At that point i looked up into general Info an everything seems to be okay, but
if i type *#06# in Phone there is nothing. (nothing happend, no popup window)
At the moment Phone stay in activation Mode without Imei. But in General Info
there everything present. (i activate by jailbreak) Cant activate with iTunes, itunes
say there is noch simcard installed.
Anyone got any idea?
I search on pcb for broken lines by microscope but i couldnt find anything, pcb are
in very good optical condition.
Old 08-25-2012, 15:21   #10 (permalink)
dog68's Avatar
Member: 1728699
Thanks Meter: 212
No one says how the problems started? ?
Old 08-25-2012, 15:26   #11 (permalink)
Member: 1159444
Thanks Meter: 7
my Problem started with fallin on the floor, sorry.
On L3 i have on both sides 1,35 volts on L2 i have on both sides 1,83 volts.
Volts on FL6 nd FL8 have 4,22 volts on every point.
Old 08-26-2012, 03:26   #12 (permalink)
Cheater -Don't Deal with him-
Member: 1797470
its baseband problem
Old 08-26-2012, 05:38   #13 (permalink)
Member: 1770097
Thanks Meter: 17
Time to reball the chip. I think you cracked the solder joints under the chip.
Old 08-26-2012, 07:06   #14 (permalink)
Member: 1159444
Thanks Meter: 7
Thx for this help too.
In Facts this ist other Phone, then taht in the other thread.
This Phone here i will wait, because it is not mine, at the other i will try to reball Chip.
Thx
Old 08-26-2012, 09:00   #15 (permalink)
Member: 1770097
Thanks Meter: 17
Look under microscope to see if the glue around chip is cracked anywhere.
If you find cracks, most likely solder cracked too and will need reballing.
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE Ģ40 (1+) -- Ģ30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Page generated in 0.24765 seconds with 10 queries
