01-30-2014, 15:22 | #16 (permalink) |
Freak Poster Join Date: Mar 2007 Location: u.k
Member: 467279 Status: Offline Thanks Meter: 42 | iphone 4 fake charging ok i changed battery 3 times jumpered the fuses for usb jumpered the power ic 3 connector toggether i change charger port tested ok i replace coil for charging still fking no work ,please can someone help me solve |
01-30-2014, 16:02 | #18 (permalink) |
Member: 467279 Status: Offline Thanks Meter: 42 | thank you for swift response i have checked all battery connectors,and the connections at the side they are all ok it seems that the power from charger unit is being blocked . the usb protection has been removed and the 3 connections jumpered i am not very good at schematics i need pictures,thanks for your help i know where dz31 is does it need be contentious or how to test thanks |
03-09-2014, 08:59 | #19 (permalink) |
Insane Poster Join Date: Jun 2007 Location: Cyprus
Member: 531719 Status: Offline Sonork: 100.1668332 Thanks Meter: 9 | Dear , i do other way i conect (D1+D2) on Q2 + C255 and it's charging but still losing battery quick even if i but the mobile on airplane mode . if i do jumper on fl10 and fl11 it well work ?? |
04-06-2014, 00:41 | #21 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 49
Member: 81501 Status: Offline Thanks Meter: 41 | can anyone help me with my iphone 4s it will auto on when i put the battery when try to charge it will discharge and there is little grounded or shorted....before this problem came out the phone use when still charging ang very hot..then disconnect then phone then someone calling me and the phone is off when i charge the phone is charging but it will discharge.... |
06-06-2014, 03:55 | #22 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2199985 Status: Offline Thanks Meter: 0 | New to schematics and jumping. My iPhone 4 only charges when off. When off and a cable is connected it powers on which shows that it sees something. Just replaced the battery and dock connector so the problem most likely lies on the board. Thanks. |
02-10-2015, 16:09 | #25 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Kosova Age: 34
Member: 1960495 Status: Offline Sonork: 1661130 Thanks Meter: 20 | Guys im having a problem with iphone 4 fake charging but it has also a blue screen when u turn it on on apple after some secs shows up the blue screen Sent from my Nexus 5 |
02-11-2015, 09:44 | #26 (permalink) | |
Freak Poster Join Date: Sep 2008 Location: U.S.A
Member: 856640 Status: Offline Sonork: 100.1606320 Thanks Meter: 281 | Quote:
just take a pic on portion of display connector with its components on the right side. i'll show you what resistors related with the problem... | |
The Following User Says Thank You to tochits For This Useful Post: |
02-11-2015, 11:31 | #28 (permalink) |
Member: 1960495 Status: Offline Sonork: 1661130 Thanks Meter: 20 | Big thannks mate but i have those 2 resistors their also working Sent from my Nexus 5 Last edited by DenisJanuzi; 02-11-2015 at 11:54. |
02-11-2015, 23:46 | #29 (permalink) |
Member: 856640 Status: Offline Sonork: 100.1606320 Thanks Meter: 281 | Can you try removing that 2 resistors, first with out changing it and then check the device? If no luck.. Change it. Thanks Bro Tochits |
The Following 2 Users Say Thank You to tochits For This Useful Post: |
04-15-2015, 09:09 | #30 (permalink) |
Junior Member Join Date: Apr 2014 Location: Tirana, Albania Age: 37
Member: 2163928 Status: Offline Thanks Meter: 4 | hello i have an iphone 4 which does not power on. i dont know exactly what caused it. after charging the battery externally it just heats up the inductors near the pmic. i didnt find anything shorted. maybe the pmic itself has screwed? thanks. |
