Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-27-2012, 23:04   #1 (permalink)
Member: 1831480
iPhone 4 - No Service No Signal - Capacitor and antenna problem?
Hi to all,
this is my first post here. I heard about this forum on another website...that hear are professionals and they could help me maybe.
So my problem...i have bought an used iPhone 4 which is factory unlocked and jailbreaked. When i put my sim card inside i can use
WIFI without problems, but i don't get phone signal...always searching and no signal - no service.
So i decided to open the phone, and look...
- i see a broken signal antenna which was not connected anymore (I will buy a new one and replace it)
- the battery bracket connector was not there - somebody removed it and lost (I will buy a new one and replace it)
- i don't see the small blue capacitor-coil...and there shold be another small capacitor (smd)...look at the picture (?????)
Picture: http://oi46.tinypic.com/n532i8.jpg
Can somebody tell me if this is normal that there is no capacitor near the antenna connection? I looked on other pictures of iphone logic boards and
saw, that they have a small blue capacitor there and also another one capacitor, which is same size but not blue.
Should i buy new smd capacitors and solder on the board or? What are the suggestions...and what type of capacitor is this...what mode, how many V and what capacity in uF?
Thank you guys for your help in advance!
Old 10-27-2012, 23:36   #2 (permalink)
Member: 1792323
simple problem replace the blue inductor and the capacitor(the cap is needed only for signal resonance smoohing-not life threatning)
Old 10-28-2012, 07:34   #3 (permalink)
Member: 48933
check replay on other forums you posted your problem
wbr,A
Old 10-28-2012, 15:08   #4 (permalink)
Member: 1831480
Thanks for the Answers guys...but...
what kind of blue inductor is this? What model, type name...or how and where can i buy this except ****? I belive it's a normal inductor with blue color, or? And what kind of cap is the small one near the blue inductor?
@backbiter17: thanks for the answer in the other forum. It's also good to post all information here, if somebody after will need it.
Old 10-28-2012, 15:14   #5 (permalink)
Tommyservice's Avatar
Member: 1829364
Sonork: 1001623211
Arrow ...
Old plate and take it to take off and put on your do not buy it all brother...
The Following User Says Thank You to Tommyservice For This Useful Post:
Old 10-28-2012, 17:26   #6 (permalink)
Member: 1792323
iPhone 4 - CyberDocLLC.com Your Repair Solution for iPhone, iPod , iPad and Apple Prodcuts
costs 5 dollars only!!lol best to order from here cuz digikey wants a min of like 500 inductors...4.3nH 03015 size..hardtofind
the cap is
1.00pf +/-0.1PF 25V
COG type 0201
The Following 2 Users Say Thank You to ps3xbox For This Useful Post:
Old 10-28-2012, 19:53   #7 (permalink)
Member: 1679608
you can make jumper for this coil anyway if you lost this coil you must have 1 point signal but now you try and make jumper for this coil and search manual check if it find any network or no and be careful dont give it to much heat because its near from bb ic if you give it to much heat you will lose the IMEI
The Following User Says Thank You to air_chair256 For This Useful Post:
Old 10-28-2012, 21:57   #8 (permalink)
Member: 1831480
@Tommyservice - Thanks. I have some computer motherboards...could take it from there, but im little afraid i don't have that much experience to do this...and also not the prober tools. Maybe i can buy a small heatgun to solder smd's and watch some tutorials on youtube...
@ps3xbox - Thanks for this information. This is very helpfull. I have to decide if i order more, and sell the other after or just buy one
@air_chair256 - Thanks for this advice. Do you have a tutorial somewhere, where i can have a look how to do this?
Old 12-02-2012, 21:00   #9 (permalink)
Member: 1831480
Hi to all
1. I did replace the antenna cable
2. I just solder a bridge between the two spots - where the blue coil should be
and the signal is working now. Thanks to everybody
Old 12-02-2012, 23:33   #10 (permalink)
noobfix's Avatar
Member: 1738165
http://www.youtube.com/watch?v=R2dDWrL7mto
CyberDocLLC iPhone 4 4G 4S 4GS No / weak GSM Signal fix Blue Inductor Coil replacement Repair
Page generated in 0.41075 seconds with 11 queries
