Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-17-2012, 19:54   #1 (permalink)
Member: 1405152
Sonork: adamsz123
iphone 4 , USB solution- iphone isn't detected
HEllo, i am trying to fix an iphone which is not charging and not detected at all no pc, (happened Because of car charger)
tried . Q2 , the 6 steps procedure by wites , tried, checked all resistors next to dock + diode , changed power ic, everything doesn't work. even changed r2,l3,l4
the phone is charged when its off and turns on when i plug usb ,
l2 has got 3.6 V Q2 got 5 V all resistors next to L2|_pmu, is correct ,
What can i do ?
thanks for the genius who can solve this
The Following User Says Thank You to adamsz For This Useful Post:
Old 06-17-2012, 19:55   #2 (permalink)
Member: 1405152
Sonork: adamsz123
sorry for the double topic , i thought it didn't send sorry
Old 06-17-2012, 20:51   #3 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
What can i do ?
Chk battery ways if ok chk DZ31 if not short,make readings to gnd of 2 usb lines and post result.
Possible CPU damaged there was a thread by airchair i think same problem was he solve by replace cpu.
The Following User Says Thank You to Wites OM Tesla For This Useful Post:
Old 06-17-2012, 21:18   #4 (permalink)
Member: 1405152
Sonork: adamsz123
thanks wites, i am going to check it , ill make a post later !
Old 06-17-2012, 21:44   #5 (permalink)
Member: 1405152
Sonork: adamsz123
replaced dz31 , no success, still looks unplugged... /;-
Old 06-17-2012, 21:46   #6 (permalink)
Member: 1405152
Sonork: adamsz123
can u refer a bit more about 2 lines of usb ground ?
Old 06-17-2012, 22:03   #7 (permalink)
Moderator
Member: 1017374
Take multimeter switch to diodes testing put red probe to gnd and black to one of 2 usb lines test them both see what numbers they show post result.
Old 06-17-2012, 22:13   #8 (permalink)
Member: 1405152
Sonork: adamsz123
you mean on j3 ? one of the 4 lines that are connected to l3, l4 ?
Old 06-17-2012, 22:17   #9 (permalink)
Member: 1405152
Sonork: adamsz123
red probe to ground and Black to ? where is this line ?
Old 06-17-2012, 22:30   #10 (permalink)
Member: 1405152
Sonork: adamsz123
or you mean to the lines from u52 ? USB11_D+ /- ?
Old 06-18-2012, 05:06   #11 (permalink)
Member: 675717
This is not rx tx problem.Just solve charging everything will be ok.Also this is not CPU problem.Don't touch CPU.I solved this type of problem.
Old 06-18-2012, 09:34   #12 (permalink)
Moderator
Member: 1017374
Yes i mean this you check to gnd to see if they are ok make some readings.
Is there some reaction when you insert charger did you try other dock flex?
To manibul
Hey dude if you are so smart why don't you post how you solve?
Each problem have different ways of solving.
The Following 2 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 06-18-2012, 10:10   #13 (permalink)
Member: 1679608
hi my friends before check the CPU replace Q1 . Q3 .DZ5 .R95 if not solved change the baseband CPU and baseband FLASH and the last replace CPU (A4) your phone not charging cuz have short in some part
The Following User Says Thank You to air_chair256 For This Useful Post:
Old 06-18-2012, 21:31   #14 (permalink)
Member: 1405152
Sonork: adamsz123
ok guys so , first thanks for everything, 2nd,
air chair : replaced all of them , result : not working.
wites :
results :
so 2 tests
1. r26 : usb11_d+ diode mode check: 1.097 v then disconnect usb after 5 sec beep and 0.100 v and after a 2 sec 1.097 again - no beep
2. r27 usb11_d- diode mode check 1.795 v then when disconnect usb after 5 sec beep and 0.160 V and then back again with no beep to 1.795
i think i am getting crazy.
manibul: why are you posting words without meaning , if you have a result please post.
thanks wites and air chair 256
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-27-2012 11:00
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
£2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 09:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-08-1999 09:14
Page generated in 0.41107 seconds with 11 queries
