01-30-2014, 23:21 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Canada Age: 55
Member: 2074110 Status: Offline Sonork: 92458589.7230895 Thanks Meter: 10 | iPhone 4 - Water damaged - Need help Water damage, screen has no display even with new screen. At first I would try a restore and I'd get error 4005. I heated up the Toshiba NAND chip really hot (in general, the entire motherboard), then put the phone in the freezer for 20 minutes then restored cold. The phone restored correctly (with no display of course) and directly aftter the phone wont recognized in iTunes nor will the display work with a new screen. I could start by cleaning the contacts. Also, something else to note, the flashlight by the camera has been very dimly on the entire time. Any help is really thanked. |
01-31-2014, 01:52 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | U mean before heating nand , set was recognized by itunes but after heating and freezer process, set is not detected in itunes am i rite |
The Following User Says Thank You to HUM For This Useful Post: |
01-31-2014, 22:52 | #3 (permalink) |
Member: 2074110 Status: Offline Sonork: 92458589.7230895 Thanks Meter: 10 | BEFORE heating up NAND, error 4005 when restoring AFTER heating up NAND then cooling off in freezer, succesfully restored, nothing showed on screen ever, and the phone is not recognized as soon as after the message said it was done restoring it. Any advice? Thanks! |
02-01-2014, 06:19 | #5 (permalink) |
Member: 2074110 Status: Offline Sonork: 92458589.7230895 Thanks Meter: 10 | Ok so I got it to recognize in itunes. Still no display though. After the itunes ssays succesful restore, the iphone wont boot back up. |
02-01-2014, 16:23 | #7 (permalink) |
Member: 2074110 Status: Offline Sonork: 92458589.7230895 Thanks Meter: 10 | So another update. All night I left the phone in a dock (That wasnt plugged in) and I woke up early to find out the LCD was bright white. What does this mean? Does anybody ahve any ideas? |
02-01-2014, 22:17 | #9 (permalink) |
Member: 2074110 Status: Offline Sonork: 92458589.7230895 Thanks Meter: 10 | I only did that once. I cannot learn if nobody is helping though!! Another update on the phone, I got the screen to work. It restores successfully, then turns off to turn back on in recovery mode. I would appreciate some "helpful" input please. Not just "go punch a wall" crap. Thank you. |
02-02-2014, 00:20 | #12 (permalink) |
No Life Poster Join Date: Mar 2012 Location: cambridgeshire, England Age: 55
Member: 1728699 Status: Offline Thanks Meter: 212 | You need to download the schematics, here on forum, Sometimes home button causes recovery loop, when shorted, but yours is fine, so no need to remove. |
02-02-2014, 00:22 | #13 (permalink) |
Member: 1728699 Status: Offline Thanks Meter: 212 | Have you tried tiny umbrella to kick it out of recovery? or ireb. it may work. |
The Following User Says Thank You to dog68 For This Useful Post: |
02-02-2014, 23:10 | #14 (permalink) |
Member: 2074110 Status: Offline Sonork: 92458589.7230895 Thanks Meter: 10 | No...good idea. I use TinyUmbrella so I just might try that. (Ran into the same issue again, wont restore with error 4005... ) Thanks for the help. I also need help with a couple other iphones...I made threads on them. Thnx |
