Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-29-2012, 10:10   #1 (permalink)
Member: 1678566
iPhone 4 WEAK Wifi
I tried changing the screw, the metal black bracket, I even put the logic board into another frame and the wifi works, however wifi isn't as strong as it should be.
Works on my floor where my router is but doesn't work in the basement.
Any solutions to this?
The Following User Says Thank You to adaseb For This Useful Post:
Old 03-29-2012, 18:36   #2 (permalink)
Member: 1703355
Ok, i'm not sure if i will help you, cause you probably know about this. You said you changed the screw, but are you sure there was that little metal piece on the EMI SHIELD? Here's the photos for you to check. Once i had that problem, and i lost the little piece, so instead, i adapted a little piece from a screw.
The Following User Says Thank You to fcporto For This Useful Post:
Old 03-29-2012, 23:12   #3 (permalink)
Member: 1678566
Yes I checked that part, even changed it with another one but I get the same problem.
It has to be the logic board because in the same housing another iPhone 4 had perfect wifi reception.
Nothing looks missing on the board and the board was never water damaged or anything, only dropped.
Old 03-30-2012, 08:49   #4 (permalink)
noobfix's Avatar
Member: 1738165
is your blue coil still there?
YouTube - iPhone 4 No Signal or No Wifi fix Blue Inductor Coil repair Apple part CyberDoctorMD.com
Old 03-30-2012, 11:35   #5 (permalink)
Member: 1678566
Yes the coil is still there.
The WIFI is not low, maybe 50% of what it should be.
It works on the first level of my house. But doesn't work on the 2nd level or on the basement while other iPhone 4 do.
Its not the metal clip, or the housing. It has to be something on the logic board.
Old 03-31-2012, 21:11   #6 (permalink)
Member: 281324
Yes. Yes. Yes. My problem is finish
Old 03-31-2012, 22:57   #7 (permalink)
bux_harun's Avatar
Member: 1638915
Thumbs up 100% solusan
Hot I iphone 4 Low wifi signal 100% Tested
Chack Thise link 100% Tested
Old 04-02-2012, 09:55   #8 (permalink)
Member: 1678566
Unfortunately that didn't solve my problem.
All I know is the phone was dropped very badly where it cracked the LCD screen inside. Is there any chip that I should reflow or reball that might have microcracks?
Old 06-25-2012, 10:39   #9 (permalink)
Member: 1678566
anyone else get this problem
please help...
Old 07-26-2012, 09:10   #10 (permalink)
Member: 1678566
anyone out there has this problem
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-27-2012 11:00
sp lock 1,2,3,4 removed spterminator Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 10 08-09-2010 10:20
All 4 locks on 6110 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 04-19-2010 02:44
£2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 09:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Page generated in 0.34979 seconds with 11 queries
