07-02-2014, 08:27 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2214998 Status: Offline Thanks Meter: 0 | iPhone 4 won't turn on and really hot when charging I hav an iPhone 4 that won't turn on and also gets hot when charging I've tried the reset and nothing ! I've tried to put in dfu mode and nothing it fails. I've tried a new screen , still nothing I've tried new battery and also tried a new proximity sensor With no luck !! I've tried stoppin and starting the apple services in control panel and also reinstalling the drivers, still nothing Tried a new charging port and nothing works !! The mother board just above the charge port connected gets really hot when charging so I'm beginning to think this is where the problem lies Any advice will be appreciated The only warning I get is when plugged into the comp it comes up with a warning that the USB device has malfunctioned please try unplugging and pluggin it in again Help please !!! :-( |
07-02-2014, 11:05 | #2 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2212078 Status: Offline Thanks Meter: 0 | Hi! Definetly your problem is in the logic board (the one that gets hot). Look what compenent in the board is the one is getting hot cause probably there is your problem. Cheers!!! |
07-02-2014, 13:27 | #4 (permalink) |
Member: 2214998 Status: Offline Thanks Meter: 0 | Battery has been replaced thanks The component getting warm is under the black heat film so means I would hav to effectively open the board up :-0 Bit beyond my capabilities really Thank you |
07-02-2014, 15:57 | #5 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2045117 Status: Offline Thanks Meter: 7 | Can be a shorted capacitor. Here on the forum you can find some layouts of mostly shorted capacitors. The first step I would take is to test all of these. You also can confirm a short by measuring the resistance between the - en + of the battery connector on the logic board. |
07-02-2014, 18:51 | #6 (permalink) |
Member: 2214998 Status: Offline Thanks Meter: 0 | Thanks for the advice Just to update When plugged into charger it has stopped gettin hot , and now when plugged into the computer it won't even recognise it ! Nothing happens not even an error message :-( Guess the board or capacitor is goosed ! Prob not gonna be cheap to repair , may just sell it as spares may b best option |
07-03-2014, 08:35 | #9 (permalink) | |
Member: 2045117 Status: Offline Thanks Meter: 7 | Quote:
Did you measure the resistance between the - and + and the battery connector ? (The 2 pins, one at the left and the other at the right, the 2 in the middle are there for another reason). So you measure the resistance between the 2 pins and let me know. If the resistance is low then there (mostly) is a short on the board somewhere. | |
07-09-2014, 00:34 | #10 (permalink) |
Member: 2214998 Status: Offline Thanks Meter: 0 | Hi Sorry for the late reply , it measures around 35 k Ohms after flucuatimg from 2 k ohms up to bout 200 k ohms As im not sure if this is normal i will leave it up to your expertise Thanks Again |
