05-16-2015, 23:36 | #1 (permalink) |
Crazy Poster Join Date: Jul 2014
Member: 2230661 Status: Offline Thanks Meter: 2 | iphone 4s backlight fl3 and fl4 jumpers Need Help Fl3 and Fl4 I've been searching around and non of the posts show jumpers when trace is off. looking to properly jumper these too to get backlight working again on this iPhone 4s. Thanks in advance and looking forward to hearing from everyone. https://drive.google.com/file/d/0B98...ew?usp=sharing |
05-17-2015, 15:48 | #3 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Quote:
Search for those two filters and try to point out to which other parts the supply goes through. You can even trace the supply with the help of a multimeter and a working 4s motherboard. Once the point is found where the supply goes you can trace thin insulated wire And jumper its one end to the point and the other point to the visible part of the broken filter. P.S: I could have made a good pic for the solution, but im not in my office. P.S2: Have you tried scraping on the peeled off track with sharp needle? If you scrape carefully you can find very tiny copper dots, that would be your supply you are searching for. Last edited by CDMA_RASHID; 05-17-2015 at 15:56. | |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
05-18-2015, 23:20 | #4 (permalink) |
Member: 2230661 Status: Offline Thanks Meter: 2 | i appreciate it when you get in the office if you have a chance i would love your picture!!! after cleaning the board i do see the copper dot. do you think i can fill it with solder to make a new pad? |
