12-19-2014, 01:52 | #1 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2313176 Status: Offline Thanks Meter: 0 | iPhone 4s Error 1 U18_RF Question Please Help! Now I want to take this step by step, and I also seen people saying that U18_RF u can jump pin 2 and pin 4 and that should work. So I want to try to start with that and see if it works before I try the solution above. I found the diagram: Now I dont know which pins are 2 and 4 on the mobo? Can someone help me on that? Here is my motherboard pic: As you can see, I already removed U18_RF, and see the copper pads (6 of them). I used my multimeter to see which one is GND and found the top right one to be. Can someone please tell me which ones to make a jumper (bridge?) Thank you. |
01-06-2015, 18:39 | #3 (permalink) | |
Insane Poster Join Date: Oct 2010 Location: Everywhere
Member: 1413143 Status: Offline Thanks Meter: 15 | U18_RF solution Quote:
here is you're solution. i got same error 1 when trying to restore an iphone 4S, and after a carefully look, i discovered that U18_RF was totaly removed by someone else from the board. after making jumper, it worked flawless. | |
The Following 3 Users Say Thank You to Udini For This Useful Post: |
01-28-2015, 09:08 | #4 (permalink) |
Insane Poster Join Date: Oct 2013
Member: 2056113 Status: Offline Thanks Meter: 20 | Is anyone here have an any idea..coz i have here Iphone 4s same problem as post at the top.then i'm done making that jumper said but same problem "occured error 1" so i proceed to the second step about U18_RF and make again second jumper..when done of jumpering that said parts..The problem is still appear when i try to restore the iphone 4s.. So of now my phone have two jumpers on board...nothing change..is anyone here can give me an idea..Thank you. |
03-13-2015, 12:00 | #5 (permalink) | |
Member: 1413143 Status: Offline Thanks Meter: 15 | Quote:
