Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-19-2014, 01:52   #1 (permalink)
Member: 2313176
Exclamation iPhone 4s Error 1 U18_RF Question Please Help!
Hey everyone I have an iPhone 4S that keeps getting an error 1. It had "searching" before and when i restored in itunes it gets an error 1 about 60% in when its almost done. I have been looking around and doing some research, and came across these:
Now I want to take this step by step, and I also seen people saying that U18_RF u can jump pin 2 and pin 4 and that should work. So I want to try to start with that and see if it works before I try the solution above. I found the diagram:
Now I dont know which pins are 2 and 4 on the mobo? Can someone help me on that? Here is my motherboard pic:
As you can see, I already removed U18_RF, and see the copper pads (6 of them). I used my multimeter to see which one is GND and found the top right one to be. Can someone please tell me which ones to make a jumper (bridge?) Thank you.
Old 12-24-2014, 11:06   #2 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 532
Don't jumper, just replace the IC. Then your error 1 is fixed
Old 01-06-2015, 18:39   #3 (permalink)
Member: 1413143
Thanks Meter: 15
U18_RF solution
Originally Posted by iPh0neMan995 View Post
Hey everyone I have an iPhone 4S that keeps getting an error 1................................................
here is you're solution.
i got same error 1 when trying to restore an iphone 4S, and after a carefully look, i discovered that U18_RF was totaly removed by someone else from the board.
after making jumper, it worked flawless.
The Following 3 Users Say Thank You to Udini For This Useful Post:
Old 01-28-2015, 09:08   #4 (permalink)
Member: 2056113
Thanks Meter: 20
Is anyone here have an any idea..coz i have here Iphone 4s same problem as post at the top.then i'm done making that jumper said but same problem "occured error 1" so i proceed to the second step about U18_RF and make again second jumper..when done of jumpering that said parts..The problem is still appear when i try to restore the iphone 4s..
So of now my phone have two jumpers on board...nothing change..is anyone here can give me an idea..Thank you.
Old 03-13-2015, 12:00   #5 (permalink)
Member: 1413143
Thanks Meter: 15
you should start 1st with U18_RF, and not with the other one.
Old 04-07-2015, 07:30   #6 (permalink)
Member: 2056113
Thanks Meter: 20
sorry for late reply on the question sir,so meaning there is no hope that can this fix?cause i apply this 2 jumper on the unit...but same problem error 1.
Old 05-21-2015, 15:55   #7 (permalink)
Member: 554917
techjhul
try replase U18_RF with U20_RF, after flash unit and replase again
The Following User Says Thank You to bes1de For This Useful Post:
Old 08-13-2015, 18:21   #8 (permalink)
Member: 1377622
Thanks Meter: 5
Unhappy
holla
i have same error with my iphone 4 i tray all software sol but no luck :/
i want to know if this method work with my iphone 4 !
plz help me ...
Page generated in 0.17669 seconds with 8 queries
