07-05-2014, 23:33 | #1 (permalink) |
Junior Member Join Date: Oct 2013 Location: Germany, Düsseldorf
Member: 2051332 Status: Offline Thanks Meter: 1 | Iphone 4S -> iTunes Error 4014 -> restoring not possible After he changed the display the problem began: IPhone did not start. No Picture. No Sound. Itunes didn't recognized phone. That is all i know about the history. I put the iPhone in DFU mode and iTunes found an iPhone in recovery mode. Unfortunally restoring ends with error 4014. That is all I have done until now: 1.) iTunes update to newest version 2.) Windows XP update 3.) used 4 different USB cords (2 original, 2 not original) 4.) changed dock-connector twice 5.) used 3 different batteries (1 brand new) 6.) tried restoring with and without connected flexcables (cams, sensor/ audio) 7.) bought a new notebook with win 7 and tried it 100x 8.) checked logicboard with microscope. No liquid damage. No corrosion. No obviously damaged parts 9.) checked board with beeper. No short found. 10.) disabled virusscan and firewall 11.) checked host data I think that it is a hardware failure after a fall on the floor or bad repair from previous owner. But what do I have to look for? Error 4014 means (as I know) that there is an interruption of the connection. Could it be the nand chip? I'd appreciate meaningful assistance from professionals very much. |
07-06-2014, 22:33 | #2 (permalink) |
Member: 2051332 Status: Offline Thanks Meter: 1 | After changing the battery again by using an used but absolutely original Apple Battery there is a new behaviour of iTunes: Now the procedere ends with :...Waiting for iPhone No error code. The apple appears on iPhones display with an empty statusbar. Only by pulling the USB cable i can interrupt this. Answering from iTunes with Error 9 (of course). Here are the logfiles i found: 2014-07-06 17:57:10.521 [6040:6a0]: restore library built Feb 12 2014 at 16:27:17 2014-07-06 17:57:10.521 [6040:6a0]: iTunes: iTunes 11.2.2.3 2014-07-06 17:57:10.521 [6040:6a0]: iTunes: Software payload version: 11D257 2014-07-06 17:57:10.521 [6040:6a0]: iTunes: Using MobileRestore state machine [15:58:19.0380] Changing state from 'Idle' to 'Restoring' [15:58:19.0380] device software does not support nonce generation [15:58:19.0380] requested restore behavior: Erase [15:58:19.0395] requested variant: Erase [15:58:19.0395] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0CC65528 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [15:58:20.0175] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0CC65600 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [15:58:20.0191] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 06927C88 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [15:58:20.0191] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [15:58:20.0191] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-request.plist [15:58:20.0456] amai: tss_submit_job: HttpQueryInfo returned 200 [15:58:20.0581] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [15:58:20.0581] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-response.plist [15:58:20.0628] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [15:58:20.0643] <DFU Device 067DD2B8>: production fused device [15:58:20.0643] requested restore behavior: Erase [15:58:20.0643] device software does not support nonce generation [15:58:20.0643] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [15:58:20.0643] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [15:58:20.0659] <DFU Device 067DD2B8>: operation 0 progress 2 [15:58:20.0675] <DFU Device 067DD2B8>: operation 0 progress 5 [15:58:20.0690] <DFU Device 067DD2B8>: operation 0 progress 8 [15:58:20.0706] <DFU Device 067DD2B8>: operation 0 progress 10 [15:58:20.0721] <DFU Device 067DD2B8>: operation 0 progress 13 [15:58:20.0737] <DFU Device 067DD2B8>: operation 0 progress 16 [15:58:20.0753] <DFU Device 067DD2B8>: operation 0 progress 18 [15:58:20.0768] <DFU Device 067DD2B8>: operation 0 progress 21 [15:58:20.0784] <DFU Device 067DD2B8>: operation 0 progress 24 [15:58:20.0799] <DFU Device 067DD2B8>: operation 0 progress 26 [15:58:20.0815] <DFU Device 067DD2B8>: operation 0 progress 29 [15:58:20.0831] <DFU Device 067DD2B8>: operation 0 progress 32 [15:58:20.0846] <DFU Device 067DD2B8>: operation 0 progress 34 [15:58:20.0862] <DFU Device 067DD2B8>: operation 0 progress 37 [15:58:20.0877] <DFU Device 067DD2B8>: operation 0 progress 40 [15:58:20.0893] <DFU Device 067DD2B8>: operation 0 progress 42 [15:58:20.0909] <DFU Device 067DD2B8>: operation 0 progress 45 [15:58:20.0924] <DFU Device 067DD2B8>: operation 0 progress 48 [15:58:20.0940] <DFU Device 067DD2B8>: operation 0 progress 50 [15:58:20.0955] <DFU Device 067DD2B8>: operation 0 progress 53 [15:58:20.0971] <DFU Device 067DD2B8>: operation 0 progress 56 [15:58:20.0987] <DFU Device 067DD2B8>: operation 0 progress 59 [15:58:21.0002] <DFU Device 067DD2B8>: operation 0 progress 61 [15:58:21.0018] <DFU Device 067DD2B8>: operation 0 progress 64 [15:58:21.0033] <DFU Device 067DD2B8>: operation 0 progress 67 [15:58:21.0049] <DFU Device 067DD2B8>: operation 0 progress 69 [15:58:21.0065] <DFU Device 067DD2B8>: operation 0 progress 72 [15:58:21.0080] <DFU Device 067DD2B8>: operation 0 progress 75 [15:58:21.0096] <DFU Device 067DD2B8>: operation 0 progress 77 [15:58:21.0111] <DFU Device 067DD2B8>: operation 0 progress 80 [15:58:21.0127] <DFU Device 067DD2B8>: operation 0 progress 83 [15:58:21.0143] <DFU Device 067DD2B8>: operation 0 progress 85 [15:58:21.0158] <DFU Device 067DD2B8>: operation 0 progress 88 [15:58:21.0174] <DFU Device 067DD2B8>: operation 0 progress 91 [15:58:21.0189] <DFU Device 067DD2B8>: operation 0 progress 93 [15:58:21.0205] <DFU Device 067DD2B8>: operation 0 progress 96 [15:58:21.0221] <DFU Device 067DD2B8>: operation 0 progress 99 [15:58:21.0221] WinDFU::UploadData: EOF, cbRead: 554 [15:58:21.0236] <DFU Device 067DD2B8>: operation 0 progress 100 [15:58:21.0236] WinDFU::UploadData: ZLP [15:58:21.0252] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [15:58:21.0252] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [15:58:21.0252] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [15:58:21.0252] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [15:58:24.0263] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [15:58:24.0263] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [15:58:24.0263] WinDFU::ResetDevice: resetting... [15:58:24.0341] WinDFU::FinalizeDfuUpdate: success [15:58:24.0341] <DFU Device 067DD2B8>: DFU succeeded [15:58:24.0341] Finished DFU Restore Phase: Successful [15:58:24.0559] DFU mode device disconnected [15:58:24.0559] Device removed when in state Restoring, moving device to transition state [15:58:24.0559] Changing state from 'Restoring' to 'Transitioning' [15:58:24.0559] Creating timer to monitor transition [15:58:25.0654] DFU mode device connected [15:58:25.0655] Transitioning device returned, continuing restore. [15:58:25.0655] Canceling timer [15:58:25.0656] Changing state from 'Transitioning' to 'Restoring' [15:58:25.0657] AppleDevice::GetDeviceID: failed for iBoot [15:58:25.0658] requested restore behavior: Erase [15:58:25.0658] requested variant: Erase [15:58:25.0659] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:26.0452] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is True [15:58:26.0452] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 05BF5CF8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 05BF4438 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 0CCC09F0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 0CCC0960 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 0CCC0A80 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0CCC0A38 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 0CCC0918 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 0CCC0B10 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 0CCC09A8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0CCC08D0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 0CCC0888 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 0CC8A980 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 0CC8A6B0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 0CC8A8F0 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 0CC8A668 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 0CC8A6F8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0468] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 0CC74E20 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0483] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 0CC74F40 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [15:58:26.0483] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 069258E8 [7045907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [15:58:26.0483] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [15:58:26.0483] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-request.plist [15:58:26.0639] amai: tss_submit_job: HttpQueryInfo returned 200 [15:58:26.0780] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [15:58:26.0780] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per6125.tmp/amai/debug/tss-response.plist [15:58:26.0780] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "iBSS" has been previously personalized; skipping it [15:58:26.0795] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "LLB" has been previously personalized; skipping it [15:58:26.0795] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [15:58:26.0811] <DFU Device 01F3B8D8>: production fused device [15:58:26.0811] requested restore behavior: Erase [15:58:26.0827] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:26.0827] AppleDevice::GetDeviceID: failed for iBoot [15:58:26.0827] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [15:58:26.0827] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [15:58:26.0858] <DFU Device 01F3B8D8>: operation 0 progress 0 [15:58:26.0873] <DFU Device 01F3B8D8>: operation 0 progress 1 [15:58:26.0889] <DFU Device 01F3B8D8>: operation 0 progress 2 [15:58:26.0920] <DFU Device 01F3B8D8>: operation 0 progress 3 [15:58:26.0936] <DFU Device 01F3B8D8>: operation 0 progress 4 [15:58:26.0951] <DFU Device 01F3B8D8>: operation 0 progress 5 [15:58:26.0983] <DFU Device 01F3B8D8>: operation 0 progress 6 [15:58:26.0998] <DFU Device 01F3B8D8>: operation 0 progress 7 [15:58:27.0029] <DFU Device 01F3B8D8>: operation 0 progress 8 [15:58:27.0045] <DFU Device 01F3B8D8>: operation 0 progress 9 [15:58:27.0061] <DFU Device 01F3B8D8>: operation 0 progress 10 [15:58:27.0092] <DFU Device 01F3B8D8>: operation 0 progress 11 [15:58:27.0107] <DFU Device 01F3B8D8>: operation 0 progress 12 [15:58:27.0123] <DFU Device 01F3B8D8>: operation 0 progress 13 [15:58:27.0154] <DFU Device 01F3B8D8>: operation 0 progress 14 [15:58:27.0170] <DFU Device 01F3B8D8>: operation 0 progress 15 [15:58:27.0201] <DFU Device 01F3B8D8>: operation 0 progress 16 [15:58:27.0217] <DFU Device 01F3B8D8>: operation 0 progress 17 [15:58:27.0232] <DFU Device 01F3B8D8>: operation 0 progress 18 [15:58:27.0263] <DFU Device 01F3B8D8>: operation 0 progress 19 [15:58:27.0279] <DFU Device 01F3B8D8>: operation 0 progress 20 [15:58:27.0295] <DFU Device 01F3B8D8>: operation 0 progress 21 [15:58:27.0326] <DFU Device 01F3B8D8>: operation 0 progress 22 [15:58:27.0341] <DFU Device 01F3B8D8>: operation 0 progress 23 [15:58:27.0373] <DFU Device 01F3B8D8>: operation 0 progress 24 [15:58:27.0388] <DFU Device 01F3B8D8>: operation 0 progress 25 [15:58:27.0404] <DFU Device 01F3B8D8>: operation 0 progress 26 [15:58:27.0435] <DFU Device 01F3B8D8>: operation 0 progress 27 [15:58:27.0451] <DFU Device 01F3B8D8>: operation 0 progress 28 [15:58:27.0466] <DFU Device 01F3B8D8>: operation 0 progress 29 [15:58:27.0497] <DFU Device 01F3B8D8>: operation 0 progress 30 [15:58:27.0513] <DFU Device 01F3B8D8>: operation 0 progress 31 [15:58:27.0544] <DFU Device 01F3B8D8>: operation 0 progress 32 [15:58:27.0560] <DFU Device 01F3B8D8>: operation 0 progress 33 [15:58:27.0575] <DFU Device 01F3B8D8>: operation 0 progress 34 [15:58:27.0607] <DFU Device 01F3B8D8>: operation 0 progress 35 [15:58:27.0622] <DFU Device 01F3B8D8>: operation 0 progress 36 [15:58:27.0638] <DFU Device 01F3B8D8>: operation 0 progress 37 [15:58:27.0669] <DFU Device 01F3B8D8>: operation 0 progress 38 [15:58:27.0685] <DFU Device 01F3B8D8>: operation 0 progress 39 [15:58:27.0716] <DFU Device 01F3B8D8>: operation 0 progress 40 [15:58:27.0731] <DFU Device 01F3B8D8>: operation 0 progress 41 [15:58:27.0747] <DFU Device 01F3B8D8>: operation 0 progress 42 [15:58:27.0778] <DFU Device 01F3B8D8>: operation 0 progress 43 [15:58:27.0794] <DFU Device 01F3B8D8>: operation 0 progress 44 [15:58:27.0809] <DFU Device 01F3B8D8>: operation 0 progress 45 [15:58:27.0841] <DFU Device 01F3B8D8>: operation 0 progress 46 [15:58:27.0856] <DFU Device 01F3B8D8>: operation 0 progress 47 [15:58:27.0887] <DFU Device 01F3B8D8>: operation 0 progress 48 [15:58:27.0903] <DFU Device 01F3B8D8>: operation 0 progress 49 [15:58:27.0919] <DFU Device 01F3B8D8>: operation 0 progress 50 [15:58:27.0950] <DFU Device 01F3B8D8>: operation 0 progress 51 [15:58:27.0965] <DFU Device 01F3B8D8>: operation 0 progress 52 [15:58:27.0981] <DFU Device 01F3B8D8>: operation 0 progress 53 [15:58:28.0012] <DFU Device 01F3B8D8>: operation 0 progress 54 [15:58:28.0028] <DFU Device 01F3B8D8>: operation 0 progress 55 [15:58:28.0059] <DFU Device 01F3B8D8>: operation 0 progress 56 [15:58:28.0075] <DFU Device 01F3B8D8>: operation 0 progress 57 [15:58:28.0090] <DFU Device 01F3B8D8>: operation 0 progress 58 [15:58:28.0121] <DFU Device 01F3B8D8>: operation 0 progress 59 [15:58:28.0137] <DFU Device 01F3B8D8>: operation 0 progress 60 [15:58:28.0153] <DFU Device 01F3B8D8>: operation 0 progress 61 [15:58:28.0184] <DFU Device 01F3B8D8>: operation 0 progress 62 [15:58:28.0199] <DFU Device 01F3B8D8>: operation 0 progress 63 [15:58:28.0231] <DFU Device 01F3B8D8>: operation 0 progress 64 [15:58:28.0246] <DFU Device 01F3B8D8>: operation 0 progress 65 [15:58:28.0262] <DFU Device 01F3B8D8>: operation 0 progress 66 [15:58:28.0293] <DFU Device 01F3B8D8>: operation 0 progress 67 [15:58:28.0309] <DFU Device 01F3B8D8>: operation 0 progress 68 [15:58:28.0324] <DFU Device 01F3B8D8>: operation 0 progress 69 [15:58:28.0355] <DFU Device 01F3B8D8>: operation 0 progress 70 [15:58:28.0371] <DFU Device 01F3B8D8>: operation 0 progress 71 [15:58:28.0402] <DFU Device 01F3B8D8>: operation 0 progress 72 [15:58:28.0418] <DFU Device 01F3B8D8>: operation 0 progress 73 [15:58:28.0433] <DFU Device 01F3B8D8>: operation 0 progress 74 [15:58:28.0465] <DFU Device 01F3B8D8>: operation 0 progress 75 [15:58:28.0480] <DFU Device 01F3B8D8>: operation 0 progress 76 [15:58:28.0496] <DFU Device 01F3B8D8>: operation 0 progress 77 [15:58:28.0527] <DFU Device 01F3B8D8>: operation 0 progress 78 [15:58:28.0543] <DFU Device 01F3B8D8>: operation 0 progress 79 [15:58:28.0574] <DFU Device 01F3B8D8>: operation 0 progress 80 [15:58:28.0589] <DFU Device 01F3B8D8>: operation 0 progress 81 [15:58:28.0605] <DFU Device 01F3B8D8>: operation 0 progress 82 [15:58:28.0636] <DFU Device 01F3B8D8>: operation 0 progress 83 [15:58:28.0652] <DFU Device 01F3B8D8>: operation 0 progress 84 [15:58:28.0667] <DFU Device 01F3B8D8>: operation 0 progress 85 [15:58:28.0699] <DFU Device 01F3B8D8>: operation 0 progress 86 [15:58:28.0714] <DFU Device 01F3B8D8>: operation 0 progress 87 [15:58:28.0745] <DFU Device 01F3B8D8>: operation 0 progress 88 [15:58:28.0761] <DFU Device 01F3B8D8>: operation 0 progress 89 [15:58:28.0777] <DFU Device 01F3B8D8>: operation 0 progress 90 [15:58:28.0808] <DFU Device 01F3B8D8>: operation 0 progress 91 [15:58:28.0823] <DFU Device 01F3B8D8>: operation 0 progress 92 [15:58:28.0839] <DFU Device 01F3B8D8>: operation 0 progress 93 [15:58:28.0870] <DFU Device 01F3B8D8>: operation 0 progress 94 [15:58:28.0886] <DFU Device 01F3B8D8>: operation 0 progress 95 [15:58:28.0917] <DFU Device 01F3B8D8>: operation 0 progress 96 [15:58:28.0933] <DFU Device 01F3B8D8>: operation 0 progress 97 [15:58:28.0948] <DFU Device 01F3B8D8>: operation 0 progress 98 [15:58:28.0979] <DFU Device 01F3B8D8>: operation 0 progress 99 [15:58:28.0979] WinDFU::UploadData: EOF, cbRead: 1116 [15:58:28.0995] <DFU Device 01F3B8D8>: operation 0 progress 100 [15:58:28.0995] WinDFU::UploadData: ZLP [15:58:29.0011] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [15:58:29.0011] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [15:58:29.0011] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [15:58:29.0011] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [15:58:32.0021] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [15:58:32.0021] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [15:58:32.0021] WinDFU::ResetDevice: resetting... [15:58:32.0099] WinDFU::FinalizeDfuUpdate: success [15:58:32.0099] <DFU Device 01F3B8D8>: DFU succeeded [15:58:32.0099] Finished DFU Restore Phase: Successful [15:58:32.0318] DFU mode device disconnected [15:58:32.0318] Device removed when in state Restoring, moving device to transition state [15:58:32.0318] Changing state from 'Restoring' to 'Transitioning' [15:58:32.0318] Creating timer to monitor transition [15:58:34.0347] Recovery mode device connected [15:58:34.0347] Transitioning device returned, continuing restore. [15:58:34.0347] Canceling timer [15:58:34.0347] Changing state from 'Transitioning' to 'Restoring' [15:58:34.0347] requested restore behavior: Erase [15:58:34.0362] requested variant: Erase [15:58:34.0362] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "iBSS" has been previously personalized; skipping it [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [15:58:35.0158] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "LLB" has been previously personalized; skipping it [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [15:58:35.0173] amai: _AMAuthInstallBundleCreateServerRequestDictionary: nothing to be done [15:58:35.0173] iBoot build-version = iBoot-1940.10.58 [15:58:35.0173] iBoot build-style = RELEASE [15:58:35.0173] requested restore behavior: Erase [15:58:35.0173] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0173] requested restore behavior: Erase [15:58:35.0173] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0173] unable to open device_map.txt: No such file or directory [15:58:35.0173] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:35.0173] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:35.0173] AMDeviceIoControl: GetOverlappedResult failed [15:58:35.0173] AMDeviceIoControl: pipe stall [15:58:35.0189] USBControlTransfer: error 31, usbd status c0000004 [15:58:35.0189] command device request for 'getenv radio-error' failed: 2008 [15:58:35.0189] radio-error not set [15:58:35.0189] unable to open device_map.txt: No such file or directory [15:58:35.0189] <Recovery Mode Device 06A552D8>: production fused device [15:58:35.0189] requested restore behavior: Erase [15:58:35.0189] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0189] requested restore behavior: Erase [15:58:35.0189] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0189] interface has 1 endpoints, file pipe = 1 [15:58:35.0189] [15:58:35.0189] <Recovery Mode Device 06A552D8>: operation 4 progress -1 [15:58:35.0189] unable to open device_map.txt: No such file or directory [15:58:35.0189] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:35.0189] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:35.0189] requested restore behavior: Erase [15:58:35.0189] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0189] requested restore behavior: Erase [15:58:35.0205] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:35.0205] <Recovery Mode Device 06A552D8>: operation 42 progress -1 [15:58:35.0205] requested restore behavior: Erase [15:58:35.0205] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:36.0234] <Recovery Mode Device 06A552D8>: operation 5 progress -1 [15:58:36.0593] unable to open device_map.txt: No such file or directory [15:58:36.0593] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:36.0593] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:36.0593] AMDeviceIoControl: GetOverlappedResult failed [15:58:36.0593] AMDeviceIoControl: pipe stall [15:58:36.0593] USBControlTransfer: error 31, usbd status c0000004 [15:58:36.0593] command device request for 'getenv ramdisk-delay' failed: 2008 [15:58:38.0278] <Recovery Mode Device 06A552D8>: operation 6 progress -1 [15:58:39.0292] <Recovery Mode Device 06A552D8>: operation 7 progress -1 [15:58:39.0619] <Recovery Mode Device 06A552D8>: operation 8 progress -1 [15:58:39.0619] unable to open device_map.txt: No such file or directory [15:58:39.0619] found device map entry for 0x00008940 0x00000008. boardConfig=n94ap platform=s5l8940x [15:58:39.0619] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options [15:58:39.0619] <Recovery Mode Device 06A552D8>: operation 9 progress -1 [15:58:39.0619] <Recovery Mode Device 06A552D8>: Recovery mode succeeded [15:58:39.0619] Finished Recovery Restore Phase: Successful [15:58:41.0554] Recovery mode device disconnected [15:58:41.0554] Device removed when in state Restoring, moving device to transition state [15:58:41.0554] Changing state from 'Restoring' to 'Transitioning' [15:58:41.0554] Creating timer to monitor transition [15:58:45.0427] RestoreOS mode device connected [15:58:45.0427] Transitioning device returned, continuing restore. [15:58:45.0427] Canceling timer [15:58:45.0427] Changing state from 'Transitioning' to 'Restoring' [15:58:45.0427] <Restore Device 0CB7D1C8>: operation 44 progress -1 [15:58:45.0427] requested restore behavior: Erase [15:58:45.0427] requested variant: Erase [15:58:45.0427] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:46.0241] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [15:58:46.0241] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [15:58:46.0241] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "iBSS" has been previously personalized; skipping it [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "LLB" has been previously personalized; skipping it [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [15:58:46.0256] amai: _AMAuthInstallBundleCreateServerRequestDictionary: nothing to be done [15:58:46.0256] requested restore behavior: Erase [15:58:46.0256] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:46.0272] device did not return saved USB log [15:58:46.0272] device did not return saved panic log [15:58:46.0272] connected to service com.apple.mobile.restored [15:58:46.0272] using protocol version 13 [15:58:46.0272] unable to open device_map.txt: No such file or directory [15:58:46.0272] board config = n94ap [15:58:46.0272] no value returned for BootArgs [15:58:46.0272] _copyDeviceProperty() failed for restore bootargs [15:58:46.0272] no value returned for MarketingPartNumber [15:58:46.0272] _copyDeviceProperty() failed for mpn [15:58:46.0272] requested restore behavior: Erase [15:58:46.0272] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [15:58:46.0287] value query for 'HardwareModel' returned 'N94AP' [15:58:46.0287] <Restore Device 0CB7D1C8>: operation 28 progress -1 [15:59:58.0016] RestoreOS mode device disconnected [15:59:58.0016] Device removed when in state Restoring, moving device to transition state [15:59:58.0016] Changing state from 'Restoring' to 'Transitioning' [15:59:58.0016] Creating timer to monitor transition [15:59:58.0016] recv(4824, 4) failed: connection closed [15:59:58.0016] unable to read message size: -1 [15:59:58.0016] unable to read message from device [15:59:58.0016] AMRAuthInstallDeletePersonalizedBundle [15:59:58.0391] Restore completed, status:9 [15:59:58.0391] Failure Description: [15:59:58.0391] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 9 [15:59:58.0391] Depth:1 Error:The operation couldn\U2019t be completed. (AMRestoreErrorDomain error 9 - Failed to receive message from device) 2014-07-06 23:15:57.230 [3552:1490]: restore library built Feb 12 2014 at 16:27:17 2014-07-06 23:15:57.230 [3552:1490]: iTunes: iTunes 11.2.2.3 2014-07-06 23:15:57.230 [3552:1490]: iTunes: Software payload version: 11D257 2014-07-06 23:15:57.230 [3552:1490]: iTunes: Using MobileRestore state machine [21:17:51.0516] Changing state from 'Idle' to 'Restoring' [21:17:51.0516] device software does not support nonce generation [21:17:51.0516] requested restore behavior: Erase [21:17:51.0516] requested variant: Erase [21:17:51.0516] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBEC" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0696FC10 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0696FD30 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0" [21:17:52.0312] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode" [21:17:52.0327] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 065E2288 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [21:17:52.0327] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [21:17:52.0327] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-request.plist [21:17:52.0686] amai: tss_submit_job: HttpQueryInfo returned 200 [21:17:52.0858] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [21:17:52.0858] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-response.plist [21:17:52.0920] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [21:17:52.0936] <DFU Device 05A845D8>: production fused device [21:17:52.0936] requested restore behavior: Erase [21:17:52.0936] device software does not support nonce generation [21:17:52.0936] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [21:17:52.0936] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ab93d329 [21:17:52.0967] <DFU Device 05A845D8>: operation 0 progress 2 [21:17:52.0982] <DFU Device 05A845D8>: operation 0 progress 5 [21:17:52.0998] <DFU Device 05A845D8>: operation 0 progress 8 [21:17:53.0014] <DFU Device 05A845D8>: operation 0 progress 10 [21:17:53.0029] <DFU Device 05A845D8>: operation 0 progress 13 [21:17:53.0045] <DFU Device 05A845D8>: operation 0 progress 16 [21:17:53.0060] <DFU Device 05A845D8>: operation 0 progress 18 [21:17:53.0076] <DFU Device 05A845D8>: operation 0 progress 21 [21:17:53.0092] <DFU Device 05A845D8>: operation 0 progress 24 [21:17:53.0107] <DFU Device 05A845D8>: operation 0 progress 26 [21:17:53.0123] <DFU Device 05A845D8>: operation 0 progress 29 [21:17:53.0138] <DFU Device 05A845D8>: operation 0 progress 32 [21:17:53.0154] <DFU Device 05A845D8>: operation 0 progress 34 [21:17:53.0170] <DFU Device 05A845D8>: operation 0 progress 37 [21:17:53.0185] <DFU Device 05A845D8>: operation 0 progress 40 [21:17:53.0201] <DFU Device 05A845D8>: operation 0 progress 42 [21:17:53.0216] <DFU Device 05A845D8>: operation 0 progress 45 [21:17:53.0232] <DFU Device 05A845D8>: operation 0 progress 48 [21:17:53.0248] <DFU Device 05A845D8>: operation 0 progress 50 [21:17:53.0263] <DFU Device 05A845D8>: operation 0 progress 53 [21:17:53.0279] <DFU Device 05A845D8>: operation 0 progress 56 [21:17:53.0294] <DFU Device 05A845D8>: operation 0 progress 59 [21:17:53.0310] <DFU Device 05A845D8>: operation 0 progress 61 [21:17:53.0326] <DFU Device 05A845D8>: operation 0 progress 64 [21:17:53.0341] <DFU Device 05A845D8>: operation 0 progress 67 [21:17:53.0357] <DFU Device 05A845D8>: operation 0 progress 69 [21:17:53.0372] <DFU Device 05A845D8>: operation 0 progress 72 [21:17:53.0388] <DFU Device 05A845D8>: operation 0 progress 75 [21:17:53.0404] <DFU Device 05A845D8>: operation 0 progress 77 [21:17:53.0419] <DFU Device 05A845D8>: operation 0 progress 80 [21:17:53.0435] <DFU Device 05A845D8>: operation 0 progress 83 [21:17:53.0450] <DFU Device 05A845D8>: operation 0 progress 85 [21:17:53.0466] <DFU Device 05A845D8>: operation 0 progress 88 [21:17:53.0482] <DFU Device 05A845D8>: operation 0 progress 91 [21:17:53.0497] <DFU Device 05A845D8>: operation 0 progress 93 [21:17:53.0513] <DFU Device 05A845D8>: operation 0 progress 96 [21:17:53.0528] <DFU Device 05A845D8>: operation 0 progress 99 [21:17:53.0528] WinDFU::UploadData: EOF, cbRead: 554 [21:17:53.0544] <DFU Device 05A845D8>: operation 0 progress 100 [21:17:53.0544] WinDFU::UploadData: ZLP [21:17:53.0560] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [21:17:53.0560] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [21:17:53.0560] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [21:17:53.0560] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [21:17:56.0570] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [21:17:56.0570] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [21:17:56.0570] WinDFU::ResetDevice: resetting... [21:17:56.0648] WinDFU::FinalizeDfuUpdate: success [21:17:56.0648] <DFU Device 05A845D8>: DFU succeeded [21:17:56.0648] Finished DFU Restore Phase: Successful [21:17:56.0836] DFU mode device disconnected [21:17:56.0836] Device removed when in state Restoring, moving device to transition state [21:17:56.0836] Changing state from 'Restoring' to 'Transitioning' [21:17:56.0836] Creating timer to monitor transition [21:17:57.0938] DFU mode device connected [21:17:57.0939] Transitioning device returned, continuing restore. [21:17:57.0940] Canceling timer [21:17:57.0940] Changing state from 'Transitioning' to 'Restoring' [21:17:57.0941] AppleDevice::GetDeviceID: failed for iBoot [21:17:57.0942] requested restore behavior: Erase [21:17:57.0943] requested variant: Erase [21:17:57.0943] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [21:17:58.0748] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is True [21:17:58.0748] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 05B6CAA8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0748] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 05B6CB38 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 05B6CBC8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 05B6CB80 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 05B6CD30 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 05B6CD78 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 05B6CDC0 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 05B6CE08 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 0696FB38 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 0696FB80 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 0696FBC8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 0696FC10 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 0696FC58 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 0696FCA0 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 0696FCE8 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 0696FD30 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0764] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 0696FD78 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0780] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 0696FDC0 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}" [21:17:58.0780] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 065E5140 [70F2907C]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>} [21:17:58.0780] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled. [21:17:58.0780] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-request.plist [21:17:58.0982] amai: tss_submit_job: HttpQueryInfo returned 200 [21:17:59.0154] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) [21:17:59.0170] amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/Admin/AppData/Local/Temp/Per141D.tmp/amai/debug/tss-response.plist [21:17:59.0170] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "iBSS" has been previously personalized; skipping it [21:17:59.0170] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "LLB" has been previously personalized; skipping it [21:17:59.0185] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" [21:17:59.0201] <DFU Device 0BFE9138>: production fused device [21:17:59.0201] requested restore behavior: Erase [21:17:59.0201] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only. [21:17:59.0201] AppleDevice::GetDeviceID: failed for iBoot [21:17:59.0201] WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [21:17:59.0201] WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#ce671dc7 [21:17:59.0232] <DFU Device 0BFE9138>: operation 0 progress 0 [21:17:59.0248] <DFU Device 0BFE9138>: operation 0 progress 1 [21:17:59.0263] <DFU Device 0BFE9138>: operation 0 progress 2 [21:17:59.0294] <DFU Device 0BFE9138>: operation 0 progress 3 [21:17:59.0310] <DFU Device 0BFE9138>: operation 0 progress 4 [21:17:59.0326] <DFU Device 0BFE9138>: operation 0 progress 5 [21:17:59.0357] <DFU Device 0BFE9138>: operation 0 progress 6 [21:17:59.0372] <DFU Device 0BFE9138>: operation 0 progress 7 [21:17:59.0404] <DFU Device 0BFE9138>: operation 0 progress 8 [21:17:59.0419] <DFU Device 0BFE9138>: operation 0 progress 9 [21:17:59.0435] <DFU Device 0BFE9138>: operation 0 progress 10 [21:17:59.0466] <DFU Device 0BFE9138>: operation 0 progress 11 [21:17:59.0482] <DFU Device 0BFE9138>: operation 0 progress 12 [21:17:59.0497] <DFU Device 0BFE9138>: operation 0 progress 13 [21:17:59.0528] <DFU Device 0BFE9138>: operation 0 progress 14 [21:17:59.0544] <DFU Device 0BFE9138>: operation 0 progress 15 [21:17:59.0575] <DFU Device 0BFE9138>: operation 0 progress 16 [21:17:59.0591] <DFU Device 0BFE9138>: operation 0 progress 17 [21:17:59.0606] <DFU Device 0BFE9138>: operation 0 progress 18 [21:17:59.0638] <DFU Device 0BFE9138>: operation 0 progress 19 [21:17:59.0653] <DFU Device 0BFE9138>: operation 0 progress 20 [21:17:59.0669] <DFU Device 0BFE9138>: operation 0 progress 21 [21:17:59.0700] <DFU Device 0BFE9138>: operation 0 progress 22 [21:17:59.0716] <DFU Device 0BFE9138>: operation 0 progress 23 [21:17:59.0747] <DFU Device 0BFE9138>: operation 0 progress 24 [21:17:59.0762] <DFU Device 0BFE9138>: operation 0 progress 25 [21:17:59.0778] <DFU Device 0BFE9138>: operation 0 progress 26 [21:17:59.0809] <DFU Device 0BFE9138>: operation 0 progress 27 [21:17:59.0825] <DFU Device 0BFE9138>: operation 0 progress 28 [21:17:59.0840] <DFU Device 0BFE9138>: operation 0 progress 29 [21:17:59.0872] <DFU Device 0BFE9138>: operation 0 progress 30 [21:17:59.0887] <DFU Device 0BFE9138>: operation 0 progress 31 [21:17:59.0918] <DFU Device 0BFE9138>: operation 0 progress 32 [21:17:59.0934] <DFU Device 0BFE9138>: operation 0 progress 33 [21:17:59.0950] <DFU Device 0BFE9138>: operation 0 progress 34 [21:17:59.0981] <DFU Device 0BFE9138>: operation 0 progress 35 [21:17:59.0996] <DFU Device 0BFE9138>: operation 0 progress 36 [21:18:00.0012] <DFU Device 0BFE9138>: operation 0 progress 37 [21:18:00.0043] <DFU Device 0BFE9138>: operation 0 progress 38 [21:18:00.0059] <DFU Device 0BFE9138>: operation 0 progress 39 [21:18:00.0090] <DFU Device 0BFE9138>: operation 0 progress 40 [21:18:00.0106] <DFU Device 0BFE9138>: operation 0 progress 41 [21:18:00.0121] <DFU Device 0BFE9138>: operation 0 progress 42 [21:18:00.0152] <DFU Device 0BFE9138>: operation 0 progress 43 [21:18:00.0168] <DFU Device 0BFE9138>: operation 0 progress 44 [21:18:00.0184] <DFU Device 0BFE9138>: operation 0 progress 45 [21:18:00.0215] <DFU Device 0BFE9138>: operation 0 progress 46 [21:18:00.0230] <DFU Device 0BFE9138>: operation 0 progress 47 [21:18:00.0262] <DFU Device 0BFE9138>: operation 0 progress 48 [21:18:00.0277] <DFU Device 0BFE9138>: operation 0 progress 49 [21:18:00.0293] <DFU Device 0BFE9138>: operation 0 progress 50 [21:18:00.0324] <DFU Device 0BFE9138>: operation 0 progress 51 [21:18:00.0340] <DFU Device 0BFE9138>: operation 0 progress 52 [21:18:00.0355] <DFU Device 0BFE9138>: operation 0 progress 53 [21:18:00.0386] <DFU Device 0BFE9138>: operation 0 progress 54 [21:18:00.0402] <DFU Device 0BFE9138>: operation 0 progress 55 [21:18:00.0433] <DFU Device 0BFE9138>: operation 0 progress 56 [21:18:00.0449] <DFU Device 0BFE9138>: operation 0 progress 57 [21:18:00.0464] <DFU Device 0BFE9138>: operation 0 progress 58 [21:18:00.0496] <DFU Device 0BFE9138>: operation 0 progress 59 [21:18:00.0511] <DFU Device 0BFE9138>: operation 0 progress 60 [21:18:00.0527] <DFU Device 0BFE9138>: operation 0 progress 61 [21:18:00.0558] <DFU Device 0BFE9138>: operation 0 progress 62 [21:18:00.0574] <DFU Device 0BFE9138>: operation 0 progress 63 [21:18:00.0605] <DFU Device 0BFE9138>: operation 0 progress 64 [21:18:00.0620] <DFU Device 0BFE9138>: operation 0 progress 65 [21:18:00.0636] <DFU Device 0BFE9138>: operation 0 progress 66 [21:18:00.0667] <DFU Device 0BFE9138>: operation 0 progress 67 [21:18:00.0683] <DFU Device 0BFE9138>: operation 0 progress 68 [21:18:00.0698] <DFU Device 0BFE9138>: operation 0 progress 69 [21:18:00.0730] <DFU Device 0BFE9138>: operation 0 progress 70 [21:18:00.0745] <DFU Device 0BFE9138>: operation 0 progress 71 [21:18:00.0776] <DFU Device 0BFE9138>: operation 0 progress 72 [21:18:00.0792] <DFU Device 0BFE9138>: operation 0 progress 73 [21:18:00.0808] <DFU Device 0BFE9138>: operation 0 progress 74 [21:18:00.0839] <DFU Device 0BFE9138>: operation 0 progress 75 [21:18:00.0854] <DFU Device 0BFE9138>: operation 0 progress 76 [21:18:00.0870] <DFU Device 0BFE9138>: operation 0 progress 77 [21:18:00.0901] <DFU Device 0BFE9138>: operation 0 progress 78 [21:18:00.0917] <DFU Device 0BFE9138>: operation 0 progress 79 [21:18:00.0948] <DFU Device 0BFE9138>: operation 0 progress 80 [21:18:00.0964] <DFU Device 0BFE9138>: operation 0 progress 81 [21:18:00.0979] <DFU Device 0BFE9138>: operation 0 progress 82 [21:18:01.0010] <DFU Device 0BFE9138>: operation 0 progress 83 [21:18:01.0026] <DFU Device 0BFE9138>: operation 0 progress 84 [21:18:01.0042] <DFU Device 0BFE9138>: operation 0 progress 85 [21:18:01.0073] <DFU Device 0BFE9138>: operation 0 progress 86 [21:18:01.0088] <DFU Device 0BFE9138>: operation 0 progress 87 [21:18:01.0120] <DFU Device 0BFE9138>: operation 0 progress 88 [21:18:01.0135] <DFU Device 0BFE9138>: operation 0 progress 89 [21:18:01.0151] <DFU Device 0BFE9138>: operation 0 progress 90 [21:18:01.0182] <DFU Device 0BFE9138>: operation 0 progress 91 [21:18:01.0198] <DFU Device 0BFE9138>: operation 0 progress 92 [21:18:01.0213] <DFU Device 0BFE9138>: operation 0 progress 93 [21:18:01.0244] <DFU Device 0BFE9138>: operation 0 progress 94 [21:18:01.0260] <DFU Device 0BFE9138>: operation 0 progress 95 [21:18:01.0291] <DFU Device 0BFE9138>: operation 0 progress 96 [21:18:01.0307] <DFU Device 0BFE9138>: operation 0 progress 97 [21:18:01.0322] <DFU Device 0BFE9138>: operation 0 progress 98 [21:18:01.0354] <DFU Device 0BFE9138>: operation 0 progress 99 [21:18:01.0354] WinDFU::UploadData: EOF, cbRead: 1116 [21:18:01.0369] <DFU Device 0BFE9138>: operation 0 progress 100 [21:18:01.0369] WinDFU::UploadData: ZLP [21:18:01.0385] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [21:18:01.0385] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [21:18:01.0385] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [21:18:01.0385] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [21:18:04.0396] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [21:18:04.0396] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [21:18:04.0396] WinDFU::ResetDevice: resetting... [21:18:04.0474] WinDFU::FinalizeDfuUpdate: success [21:18:04.0474] <DFU Device 0BFE9138>: DFU succeeded [21:18:04.0474] Finished DFU Restore Phase: Successful [21:18:04.0676] DFU mode device disconnected [21:18:04.0692] Device removed when in state Restoring, moving device to transition state [21:18:04.0692] Changing state from 'Restoring' to 'Transitioning' [21:18:04.0692] Creating timer to monitor transition [21:18:08.0230] Restore completed, status:4014 [21:18:08.0230] Failure Description: [21:18:08.0230] Depth:0 Error:Unexpected device state 'DFU' expected 'Recovery' |
10-16-2014, 06:10 | #3 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2274985 Status: Offline Thanks Meter: 0 | I have exactly the same problem with an iPhone 5. Restore freezes on the Apple logo with an empty progress bar. The log hangs at same line as you: <Restore Device xxxxxxx>: operation 28 progress -1 And only way to move away is to disconnect the device (and fail the restore). Did you have any info after your post by any chance? |
