09-25-2014, 17:39 | #1 (permalink) |
Major Poster Join Date: Dec 2013
Member: 2088670 Status: Offline Thanks Meter: 6 | iPhone 4s missed two components near battery connector Could you help me to identify the correct component and can you tell me where i can buy them? Now i can power on the iPhone only when it's in charge. Thank you all |
09-25-2014, 18:25 | #2 (permalink) |
Member: 2088670 Status: Offline Thanks Meter: 6 | I've found the schema for the iPhone 4s and that components are two capacitors C294 and C295. Where can i buy these capacitors? |
The Following User Says Thank You to calamar0 For This Useful Post: |
09-25-2014, 18:41 | #3 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | what problem in your phone,,, i think capacitor are no rizen of any problem they create problem if short butt no problem if removed |
09-25-2014, 19:01 | #4 (permalink) | |
Member: 2088670 Status: Offline Thanks Meter: 6 | Quote:
Thank you for your reply! | |
09-27-2014, 08:58 | #5 (permalink) |
No Life Poster Join Date: Mar 2012 Location: cambridgeshire, England Age: 55
Member: 1728699 Status: Offline Thanks Meter: 212 | Remove the capacitors, and resolder the battery connector, use plenty of flux, im sure it will solve your problem. |
The Following User Says Thank You to dog68 For This Useful Post: |
09-30-2014, 15:24 | #10 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | Sorry i said fuses but they are 0ohm resistors, but they act as fuses. This is the components : J9.JPG |
The Following User Says Thank You to laptopmd For This Useful Post: |
09-30-2014, 15:29 | #11 (permalink) | |
I'll try. Thank you for your suggestion! | |
10-03-2014, 15:30 | #12 (permalink) | |
Member: 2088670 Status: Offline Thanks Meter: 6 | iPhone 4s missed two components near battery connector Quote:
I've checked all connections from the logic board battery pins to fuses/capacitors on the scheme and all work correctly. I've also removed the capacitors like that I've broken like suggested before without success. The iPhone still turns on only with the power adapter, no signs of life/battery indicator only with battery. Do you have any other suggestion? | |
10-07-2014, 09:54 | #14 (permalink) |
Member: 1873863 Status: Offline Thanks Meter: 67 | @calamar0 : when you turn on the phone using the charger, it stay on or reboot ? If stay on, when you press the power button does it react ? (screen off, screen on, etc.) |
10-07-2014, 10:22 | #15 (permalink) | |
Yes it works perfectly except the battery percentage that is ever at 100%. It seems like it doesn't recognize the battery. Like I've said before it's very strange because I've tried only to resolder the battery connector, before that moment the iPhone has worked fine. Thank you man for your support No solution at the moment. | |
