12-31-2012, 12:55 | #1 (permalink) |
Insane Poster Join Date: Mar 2006 Location: İstanbul Age: 40
Member: 242163 Status: Offline Thanks Meter: 15 | iphone 4s No Call Sound Problem FIX |
The Following User Says Thank You to Coderer For This Useful Post: |
05-19-2013, 11:48 | #5 (permalink) |
Junior Member Join Date: May 2013 Location: marvdasht
Member: 1938422 Status: Offline Sonork: [email protected] Thanks Meter: 9 | thanks.............. |
03-12-2014, 13:47 | #11 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1963154 Status: Offline Thanks Meter: 0 | Thanks a lot for the solution, I spent lots of time to fix an iphone 4S: checked everything, reballed Audio IC, replaced Audio IC and after that found your solution. Now all works fine. |
04-19-2014, 06:35 | #12 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1925555 Status: Offline Thanks Meter: 6 | If one of registers on back of headphone jack got short to metal frame and sound on ear piece became buzzing or no sound but sound is still good on louder speaker. Most happen after replace front camera and headphone jack was moved then hit to metal frame; or replace with aftermarket headphone flex which does not have good seal cover. It was made me crazy couple days... I try putting the board to other phone, it working good but then the same. I did not think about it was important until found out the bottom of the headphone jack lift up not sit right on metal frame.... Try again by cut on metal a space little bigger that let headphone jack sit correct then it work as normal. Also try which the generic one I though defected, they are working normal same as OEM one because all registers are away of metal frame. Also I learn one thing that if every time I removed the screw of wifi antenna on right side of headphone jack that made the headphone jack moved too and the bottom of the jack lift up…. Let try this before attempt fix on IC because reheat or soldering the IC that very risky will cost to lose everything if you don’t have a right tool… |
The Following User Says Thank You to emvp For This Useful Post: |
12-03-2014, 19:29 | #14 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251314 Status: Offline Thanks Meter: 2 | Working for me, Coderer thx for solution. http://i.imgur.com/OtfwDlW.jpg http://i.imgur.com/BhGVF6x.jpg |
The Following User Says Thank You to zabEx For This Useful Post: |
01-02-2015, 11:05 | #15 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Bali - Denpasar
Member: 526402 Status: Offline Thanks Meter: 8 | Quote:
- can, this problem because ios8 ??? (software) or 100% hardware ????? note: before i try to hardware... please help and answer it.. thanks you... | |
