07-14-2013, 01:36 | #16 (permalink) |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | It's availeble in iPhone 3gs board too not just in iPad Post solution with detail or commentwell, before you give dirty smile n open your big ***** |
07-14-2013, 01:38 | #17 (permalink) |
Member: 272137 Status: Offline Thanks Meter: 75 | While calling every thing stoppped we need to reball or replace U60. It's availeble in iPhone 3gs board too not just in iPad Post solution with detail or commentwell, before you give dirty smile n open your big mout.h |
02-05-2014, 17:00 | #20 (permalink) |
Freak Poster Join Date: Oct 2012 Location: London, UK Age: 34
Member: 1819464 Status: Offline Thanks Meter: 88 | HI All! I have an iPhone 4S in my workshop and the bottom MIC is not working at all, neither in Voice Recorder, neither during calls. the UP side MIC IT IS working all sounds are working I tried with 3 others Charging Units and still the same problem, ANY Solution PLEASE, I have a very unpatient customer and he is willing to pay |
04-19-2014, 07:18 | #21 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1925555 Status: Offline Thanks Meter: 6 | Any time touch to any IC that will be a risky and no time for regret because it was already done… Just think twin or more before attempt to do that if you don’t have a right tool. As my opinion, if you have a chance put the board to other good phone try let see exactly problem happen the same ? If it sounds normal then check the dock charger, if it was contacted to liquid, some pins including pins for sound function already got short, just replace new one; If you have replaced a front camera or replace a new headphone flex, you must remove the screw for wifi antenna on right side of headphone jack, make sure headphone jack sit tire on metal frame… if you see the bottom of headphone jack is lift up so some resistor on back side of headphone was short with metal frame… Try to cut a space on metal frame below headphone a little bigger that let all resistors away from metal. All those can help with no sound on ear piece during phone call or sound became buzzing or not loud even you turn volume to max level while louder speaker is still working good. I don’t have too much tools, so that way was help me most all iphone 4s in my work shop with no sound on ear piece because it believe IC on iphone 4S is not easy defected like on iphone 4. If you don’t want to lose it, try this let see you would be lucky like me ? |
04-19-2014, 07:31 | #22 (permalink) |
