05-22-2013, 17:03 | #32 (permalink) |
No Life Poster Join Date: Apr 2012 Location: < Man is stronger than stone.>
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | They mean let the battery discharge, play with iphone some games, until its turned off, let a while, than plugged in charger.. its easy task, althought sceptic that will work, but why not try it.. otherwise rehoot like we sad before on posts..sure it will work.. regards |
The Following User Says Thank You to cobra iphoni For This Useful Post: |
06-08-2013, 15:05 | #34 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1952353 Status: Offline Thanks Meter: 0 | How did you guys reheat the wifi module? I have a soldering iron, can I use it somehow? I also heard that reheating the small white thingy beside it worked. Can someone explain this or have any knowledge of it? I circled it in red. IMG_5508_new.jpg |
06-08-2013, 19:28 | #35 (permalink) |
Member: 1952353 Status: Offline Thanks Meter: 0 | So that didnt work. But I went back and did as you said, trying to reheat the wifi module this time. I removed the sticker and heated it with a soldering iron and some aluminum foil. Not sure how you guys manage to get it 300C, but i heated it enough for it to feel very hot. Then I reattached the black sticker and put the Iphone back together and Yes it worked! But I must say, it feels just like the fix that the hairdryer does too, so Im not surprise if it stops working after awhile. If you guys manage to get it to 300C, I guess it takes a lot longer for it to cool down, so it seems to be solved, but when its actually just temporary. Who knows? Please tell me if Im wrong, just thinking out loud. |
07-02-2013, 22:24 | #36 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 44
Member: 88333 Status: Offline Thanks Meter: 48 | people heat the component so that all the little circuits in that part of the phone get hot so they get removed from the motherboard and then as soon they chill out the RE-attach to the motherboard way better then they were attached before,so that doesnt mean that the wifi will work only when the component are hot instead it will work when they chill out and all the componets REATTACH to the motherboard! i hope i was able to explain myself kentxy! |
07-06-2013, 22:28 | #40 (permalink) |
Insane Poster Join Date: Sep 2011 Location: PK - UK
Member: 1657286 Status: Offline Sonork: 100.1639456 Thanks Meter: 9 | yeah this solution works 100% but is there any body who knows how to fix the same problem in iphone 4 ? as i've messed up two phones with same problem |
07-07-2013, 09:18 | #41 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Wikon, Switzerland
Member: 1012778 Status: Offline Thanks Meter: 245 | @azadtahir: On the 4 is it another module. Reheat doesn't help in the most case there, so let it better be. Was it a water-damage on your boards? First, check if you have 1.5V at L21_RF. If not, You have open the module and check for corrosion. If you see any, repair this track: |
07-08-2013, 12:09 | #43 (permalink) |
Member: 1012778 Status: Offline Thanks Meter: 245 | It's in the wi-fi module self. you have to remove the Metal-Shield (soldered). But take care when you are not a professional, it's nearly impossible!!! |
07-08-2013, 18:18 | #44 (permalink) |
Member: 1657286 Status: Offline Sonork: 100.1639456 Thanks Meter: 9 | yeah you are right well i did that but couldnt take off the wifi module but other small components come off with it now phone is taking too much power |
07-11-2013, 10:39 | #45 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Bd+Bh Age: 39
Member: 1775502 Status: Offline Sonork: 100.1618378 Thanks Meter: 221 | iPhone 4S wifi and Bluetooth solution sucesfull Phone 4S wifi and Bluetooth solution sucesfull. cheak this solution bro..................................... Uploaded with ImageShack.us |
