Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-06-2013, 11:43   #1 (permalink)
Member: 1863305
iphone 4S not charging when power ON
My iphone4S is not charging with the wall charger. The battery indicator does not change to the lightning icon. But it works when power off. And works with computer when the power on.
The charger and the cable are not defective though. I am able to use it to charge the other iphone.
Where can the problem be?
Before that, I use my car charger with the Iphone. And car charger is a HTC.
Old 01-06-2013, 17:36   #2 (permalink)
Levani_Pmic's Avatar
Member: 1679251
Thanks Meter: 385
friend at first change charging port, it's common problem and very often this detail is damaged
The Following User Says Thank You to Levani_Pmic For This Useful Post:
Old 01-07-2013, 10:10   #3 (permalink)
Member: 1863305
BUT it works well when connected to the PC.
Old 01-07-2013, 10:29   #4 (permalink)
Member: 1679251
Thanks Meter: 385
connector has 30 pins and some pins might be damaged and some pins might work
Old 01-08-2013, 02:27   #5 (permalink)
Member: 1863305
When connect the USB D+ AND D- to +1V,IT begin charge!
Old 01-08-2013, 04:11   #6 (permalink)
Member: 885948
change charging port,use original parts,100% work
Old 01-15-2013, 13:30   #7 (permalink)
Member: 1863305
I test the USB find that the Resistance between D- and ground only 174 OHM. So I made a special USB cable, D- connected to 5V with a 200 ohm series resistor. It working NOW.
Old 05-20-2013, 07:47   #8 (permalink)
Member: 201888
Thanks Meter: 62
I have same problem
Please share picture for solution
Thank
Old 06-01-2013, 12:09   #9 (permalink)
Member: 1863305
Originally Posted by mwmobile2 View Post
I have same problem
Thank
D- to 200 ohm resistor to 5V . It works nelary 6 *****.
Old 06-01-2013, 18:53   #10 (permalink)
Member: 144662
Hi
I have iPhone 4 not charging fault. There was small liquid damage on connector, I replaced battery and connector and now it shows charging but battery is not getting charged! ?
Can you help ?
Thanks
Old 08-02-2013, 13:55   #11 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
4S not charging when power on
Hello !
I have the same problem and i can't solve it ! Iphone 4S not charging when power on but it's charging when the phone is powered off ! I tried to use an other cable, an other flex but nothing, please help !
Old 02-27-2014, 20:49   #12 (permalink)
Member: 1825806
Sonork: 100.10937
i have same problem too master ..help
Old 02-28-2014, 06:57   #13 (permalink)
shanoopc's Avatar
Member: 1180290
Sonork: 100.1652502
Thanks Meter: 73
that is ur power ic (U5)problem..
change it... will be ok 1000%
Old 11-25-2015, 17:56   #14 (permalink)
Member: 1494377
Brother i change the pm ic but still problem remain... i have make the jumper near to charging ic now charging ok but does not show charging symbel....
Page generated in 0.22430 seconds with 8 queries
