02-08-2012, 09:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Malta Age: 36
Member: 1176031 Status: Offline Thanks Meter: 62 | iPhone 4S restore error -1 I have this iPhone 4S which I bought from e bay. The previous owner said it got dropped and the screen got broken and hence he sold the logicboard. Once I received the board I connected the board with a battery and installed a screen just to get a preliminary of how the logicboard behaves. However I found out that the touch function is not working. I though let's try a restore to 5.0.1 stock and at the end of the restore process the itunes throws an error, the code is -1. I think this relates to the baseband not being updated, however I can't find any real help on this error. I'm also thinking that the touch is not working due to the phone is being frozen trying to search for signal therefore the phone is out of resources to let the touch function work. Anyone has any idea what I could diagnose more or maybe a possibility to create a custom firmware for iPhone 4S without baseband update? |
02-08-2012, 10:46 | #6 (permalink) | |
Member: 1176031 Status: Offline Thanks Meter: 62 | Quote:
It's found in: %AppData%\Apple Computer\iTunes\iPhone Updater Logs And sort the folder by date, highest first | |
02-10-2012, 15:03 | #9 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1720169 Status: Offline Thanks Meter: 77 | it does not work if your baseband chip is damaged(but i think you might be lucky) here the fix as when itunes restore it gets the ssh from the apple by the gs.apple.com and gets he 2 api ticket in ios5xx one for the firmware and another for the baseband so if your phone gets a aaple logo nad get filled upto the 90% and then error comes then it means that the api ticket for the baseband was not retrieved which could be due to the server problem , hence u must try the ipsw 5.0.1 9A406 this will help you in updatig your baseband . also you must check the host file in windows>system32>driver>etc>host open this file with notepad as admin and then check the gs.apple.com Xx.xx.xx.xx does not have this so ther put # before that. try it and post result |
02-10-2012, 15:51 | #10 (permalink) | |
However take a look at the restore log and you can see the error. I suspect that the problem is within the baseband of the phone as I was able to restore another 4S on 5.0.1 9A406 firmware without any errors Code: update_baseband: requesting baseband firmware data update_baseband: received data from host (11169110 bytes) update_baseband: performing next update stage bbupdater: BEGIN: Perform stage at second bbupdater: BEGIN: Sending 1 Images bbupdater: Resuming Maverick Protocol bbupdater: Sent Manifest with length 586 bbupdater: Disconnecting...bbupdater: FAILED(kBBUReturnIOError) bbupdater: END(kBBUReturnIOError): Sending 1 Images bbupdater: END(kBBUReturnIOError): Perform stage at second send_bbupdate_status: sending baseband update status to host update_baseband: bbupdater error: kBBUReturnIOError 0: RamrodErrorDomain/3ec: update_baseband: failed to perform next stage 1: BBUpdater/10 unable to convert ramrod error 1004 attempting to dump restore log writing log file: /mnt1/restore.log | |
02-12-2012, 15:38 | #11 (permalink) |
Member: 1720169 Status: Offline Thanks Meter: 77 | is your restore to 5.0.1 9a406 was successful ??? if not then use bbupdaterextreme.exe and connect your phone in the dfu mode and thus upadte your baseband manualy more through the beta one 9B5141a (beta 3) having baseband 1.5.04 |
02-12-2012, 15:54 | #12 (permalink) |
Member: 1176031 Status: Offline Thanks Meter: 62 | Yeah I have heard of the bbupdater it's the command tool that Apple use to invoke baseband commands. Where can you download this tool and how do you use it? |
06-05-2012, 14:44 | #14 (permalink) | |
The only solution I think is to remove ic and reball it but first I will take a good look at the ic maybe there are some cracks or something. | |
06-05-2012, 19:43 | #15 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1767881 Status: Offline Thanks Meter: 0 | Thanks limespirit for repling back. I suspected the same, problem with ic. I just need to find the time and equipment to investigate the baseband chip problem. I'll let you know the outcome. |
Put in this thread all successfull story with Cyclone-box | NADEEM GONDAL | Cyclonebox | 3058 | 05-24-2019 07:07 |
Request and Share all Working Flash File By MasterTools | .::AZEEM::. | Mastertools | 1109 | 10-02-2017 15:51 |
Bugssss HTI driver error 10 (SOLVED) | ekel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 28 | 10-18-2013 09:00 |
nokia 101 flashing cable pinout? (ANSWERED) | asif_ae | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 02-06-2012 00:28 |
2700 contact service (ANSWERED) | kiran | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-05-2012 23:58 |
