04-08-2014, 21:09 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 689368 Status: Offline Thanks Meter: 0 | iPhone 4S - Restore Error 1 After Battery Replacement I am having some restore issues with a particular iPhone 4S device, and hope you guys have some insight or suggestions. Initially, I replaced the battery on the phone, and booted into iOS. The phone was stuck with a "Searching..." indication, and I tried a few things without any luck (manually setting time, airplane mode, etc.). Next, I decided to try and update the phone to the latest iOS fw, at which point the update failed (at approximately 60%), and placed the phone into a recovery loop. Now, I am having trouble restoring the phone, and receive error 1 at approximately that same 60% point. Any ideas as to what I can try to resolve the issue? Thanks! |
04-08-2014, 21:45 | #2 (permalink) |
Member: 689368 Status: Offline Thanks Meter: 0 | After some further investigation, it looks like I knocked a chip off the main board (highlighted in green): im gur . com / yABlWqo . png As I understand, I can jump this point? What is this point named? Would it be possible to simply replace the chip and re-solder it? Thanks. |
04-08-2014, 22:22 | #3 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | you have problem with baseband thread moved to hardware section |
The Following 2 Users Say Thank You to ~Leo~ For This Useful Post: |
04-18-2014, 20:02 | #7 (permalink) |
Freak Poster Join Date: Feb 2007 Location: at the top of u
Member: 455794 Status: Offline Sonork: 100.1591235 Thanks Meter: 61 | hi , dont try to reball any thing mostly on iphone 4s i always fix it by making a jumper of the ic (9 pin ic around the charging connector) i have faced that problem while i try to fix sim connector before accidentallyt it will be broken crystal icat the back of the sim connector other time use search button http://www.technicalnet.ch/iphone/4s_no_BB.jpg finally press thanks button Last edited by emush; 04-18-2014 at 20:10. |
The Following User Says Thank You to emush For This Useful Post: |
