08-22-2012, 13:36 | #17 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
08-22-2012, 17:32 | #18 (permalink) |
Major Poster Join Date: Nov 2011
Member: 1697956 Status: Offline Thanks Meter: 3 | Hi Wites, i take the number 3 red(home button) but still its getting 1611..the itunes start and at the iphone its start the apple sign with the bar and then it slowly start to get black and turn on again.. and befor someone tald me to take this out and i was take it off.. |
08-22-2012, 18:00 | #19 (permalink) | |
08-26-2012, 15:48 | #21 (permalink) |
Freak Poster Join Date: May 2008 Location: dubai, UAE Age: 36
Member: 774915 Status: Offline Thanks Meter: 1,640 | brother for iphone 4 mybe baseband problem i had same problem also i restored the phone with no basebasnd custom file then phone restored but imei was 000 so first tray one no baseband file u will understand mybe baseband ic problem |
08-26-2012, 17:51 | #22 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1159444 Status: Offline Thanks Meter: 7 | i think 16xx Errors is caused in battery or connection problems. Battery Contacts are clean and resolderd? Battery by itself is in good condition? Did you try other dockconnector? |
08-29-2012, 23:22 | #23 (permalink) |
Insane Poster Join Date: May 2006
Member: 271255 Status: Offline Thanks Meter: 9 | Ok, Been in the biz for 19 years. I have a customer who was pushed in a pool with his 4s. The phone had no power when it ws brought in. I Stripped it down to Mobo, cleaned all the flex clips and nothing. Then scrubbed down the board with my solvent(Amonia based), then let it soak a few hours, scrubbed again, then dried over night in Mobo drier. This morning it got on the Apple logo showing for about 7 seconds then off for 7 then on again. Tested everything else on phone with another board and it all worked, so its gotta be the Mobo. When I tried to reset in recovery mode it errored out with 21. Then I tried DMU and again, after a while, it errored out again. For whatever reason, Itunes on my PC wont allow me to update, but I figure its probably the Mobo. I guess I could do the whole uninstall and reinstall Itunes, but it did get to apple and load the FW, so I thought the connection was there. The shematic you show is for a 4g, do you have the exact place on a 4s when error 21 won't let you restore the phone? BTW..Nothing happens when power button is pressed. Thanx in advance...and the future |
08-30-2012, 11:34 | #24 (permalink) | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
08-31-2012, 18:15 | #25 (permalink) | |
Member: 271255 Status: Offline Thanks Meter: 9 | Quote:
I have saved hundreds(Maybe even over 1000) liquid damaged phones over the years by stripping the phone down carefully, cleaning all the components, letting then dry, and reassembling. I usually try to follow the burn marks trail through the MoBo and flexes and lightly clean them with a soft toothbrush and my solvent. I have about a 75% overall succes rate at saving a liquid damaged phone utilizing this method. I do not know where you got I bought this particular iPhone 4s from; it was a customer that brought it in as I stated in my OP. Since I got the lcd, digitizer, and everything else to work in the phone, Except the Mobo, I figured maybe I could utilize your solution mentioned above for a similar phone because I was getting the error 21 when trying to reload the FW. I do not know how to test the components with a multimeter, but would love to learn. I just wanted to know if there was something I could do to help get this phone back up and running and was willing to try something new. I can see by alot of your posts you have added invaluable information on this forum. But I also see a few posts that come accross snide and patronistic. This makes no sense to me when your posting in, and a big part of, an informational forum; peeps come here to learn and trade ideas. I would think the overwhelming majority of readers on this form, do not have a multimeter, know how to use it, or know how to read a schematic, but that's why were here, and thats why this forum exists. Once again, I thank you for the information you give; but is there anything you can suggest I do for my problem. | |
08-31-2012, 22:02 | #26 (permalink) |
Freak Poster Join Date: Aug 2012
Member: 1792323 Status: Offline Thanks Meter: 49 | my friend i can tell you water damage iphone almost NEVER works 100percent with just a simple "cleaning" you have to have knowledge of circuits, active/passive components , memorize schematics and still need a little luck; there is not one elemental "single" circuitor component to trigger error 21- there are several dozens paths of circuitry that will give error 21 or 16xx but you can start by looking at all the caps around U52 and U1 but if there is short or disconituity you must readyto reball- and did you know there are several layers of PCB in iphone if short or break is within the board you are screwed-listen you say you have experience but you dont sound like it , you should not be asking naive question to Wites it get him angry lol |
The Following User Says Thank You to ps3xbox For This Useful Post: |
08-31-2012, 23:52 | #27 (permalink) | |
I told you I have a lot of experience in taking apart the phones, replacing parts, and cleaning Mobo's from liquid damage. I also told you I did not know the components on a MoBo, or how to read the schematic. Why is it some of you feel the need to belittle despite being told by the ones youre belittling, they are novices. I havent been on this site in quite awhile, but hope this is not the direction it has turned. Hopefully it's just a few on this particular section. The guy you don't want me to piss off said in a previous post, the fix for a error 21 and 16xx on a 4s was to remove some "Cap" on a certain part of the board. He referred to a pic that was a 4g or CDMA Board, not a 4s. I just wanted constructive clarrification; that's all. | |
09-01-2012, 10:07 | #28 (permalink) |
Member: 1792323 Status: Offline Thanks Meter: 49 | hey nobody wants to belittle you or make you feel unwelcome dont take wrong way!!!the docking port is similar on 4 and 4s - the cap he is referring to is c227,- keep in mind you dont remove that cap if its not shorted or if its in range(27pF)- its the cap associated with the home/menu key , sometimes when it shorts you get 16xx errors but first change the dock port/battery assuming its hardware related (software related 16xx/21 errors could be jailbroken/ hacktivated firmware yadayada). There is also a diode in the ipn4 which may be bad, but in 4s, also check resistor 57 its near u8 (under the a5chip ) which is he logicbuffer pre pulldown for the pp1v8 (powerline)for the home/power key |
09-01-2012, 18:34 | #29 (permalink) |
Member: 271255 Status: Offline Thanks Meter: 9 | OK. I'm trying to find out if it is Jailbroken, but the customer cannot get in touch with her son because he is in the MTs. Camping. But I thought even if it was Jailbroken, it can still be reloaded in DMU mode. I will try changing out the ports; I already tried the battery swap. Is there a schematic with a diagram clearly labeling these components(Resistor 57, U8,a5chip, c227) and where theyre located? If this is uber elementary, I appologize. I take it the range your speaking of is connected to the useage of the pre-mentioned multimeter. This doesnt sound like something that can be taught thru a forum. Do you guys have a stateside repair facility, or know of one that is trustworthy enough to fix this? If it is something that can be taught thru this forum, I'd be willing to learn. |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
