Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-05-2013, 08:38   #61 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
I have an iphone 5 and drains battery fast , and auto power on , is possible that u2 be only problem ?
The Following User Says Thank You to Ionel For This Useful Post:
Old 09-10-2013, 13:04   #62 (permalink)
AHAMEDPONMALA's Avatar
Member: 723178
Thanks Meter: 37
Originally Posted by jheff2182 View Post
just change u2 ic 100% works
u2 or u3........pls conform sir
Old 09-23-2013, 11:36   #63 (permalink)
Member: 750106
restored phone using DFU mode to ios 7 . problem fixed for me
Old 09-24-2013, 06:25   #64 (permalink)
Member: 723178
Thanks Meter: 37
ipn 5
good job..........keep to share.................
Old 10-23-2013, 03:41   #65 (permalink)
Member: 1426467
Thanks Meter: 3
yes bro this is only u2 problem
Old 10-24-2013, 17:05   #66 (permalink)
Member: 2042483
hey I have the same problem when taking jumpers zaginoł me a C14: ( but once the freeze iphone phone worked, and even landed a few minutes
Old 11-03-2013, 02:43   #67 (permalink)
Member: 1416195
Sonork: 100.13966
Thanks Meter: 8
How to replace the U2 ic ? With hot air ?
Old 11-03-2013, 12:48   #68 (permalink)
Member: 2042483
as a hot air
I unfortunately did not help jumper, on the phone powers podpięciy cable, sometimes start and operate a minute, but still indicates that the battery is 100% flat to 1% and the phone goes off again. I would add that not work for me the power. I question for you, if I can turn on DFU without power button? : (
I want to load the new iso, but the computer does not detect it and the power button does not work. battery is charged via the moment and later they try to enter for iphone and charging August off, and so non-stop. I would add that the kabelku pin 3 is slightly zasniedziały and probably think only of his therefore current and therein lies the problem. cable is new and original.
Old 11-03-2013, 13:36   #69 (permalink)
Member: 1224714
change usb ic near the cpu
Old 11-03-2013, 15:01   #70 (permalink)
Member: 1416195
Sonork: 100.13966
Thanks Meter: 8
How to replace this IC in safe ?
Old 11-11-2013, 08:35   #71 (permalink)
Registered User
Member: 892016
Thanks Meter: 29
Old 11-11-2013, 14:46   #72 (permalink)
memas_trading's Avatar
Member: 1797460
Sonork: 100.1622335
Thanks Meter: 24
bro change the u2 in shah allah it,s done
Old 11-21-2013, 16:30   #73 (permalink)
Member: 1067900
Thanks Meter: 5
Sir,
I found your posts very nice. Please help me with my problem.
I have an iPhone5 which was working good. But then one day I left it turned off (battery %age was 20-25%). I left if off for 7days and then when I tried to charge my iPhone it didn't charged.
I kept it connected for more than 10hrs but still no power.
I then decided to open and check the battery. I check the pins of the FPC Connector of the battery which connects to the motherboard with a multimeter and was showing ony 0.2- 0.6volts (all 4 terminals, 2 at a time). I cracked open the battery and the charge on battery pin (not on FPC connector was 3.2v) I then charged it by soldering wire on it and charge was near 4v.
But I put it back on iPhone it still does not power On.
Please tell me what possibly could be the issue. Still the connector pin of battery is showing 0.2v -0.6v
Pleaseeeeeeee
Old 11-21-2013, 17:29   #74 (permalink)
Member: 2069700
good job..........>>>>>>>>>>
Old 11-26-2013, 13:11   #75 (permalink)
Member: 2066584
You can try to set your Iphone to its original settings
Page generated in 0.20759 seconds with 9 queries
