03-10-2015, 22:50 | #1 (permalink) |
Major Poster Join Date: Mar 2008
Member: 726059 Status: Offline Thanks Meter: 1 | iPhone 5 battery drain Miss composantes On an iPhone 5 i've got a problem with battery, go down in less 3 Hours, and when down impossible to charge it again. After having a look on the board, i see that it miss somme composantes Miss FL 54 FL 18 C 13 C 12 L 20 my question if i replace all charge Will be Ok ? Can i jump some ? Thanks ! |
03-12-2015, 11:02 | #2 (permalink) |
Junior Member Join Date: Sep 2011 Location: Netherlands / OV / Hengelo Age: 39
Member: 1648562 Status: Offline Thanks Meter: 5 | Bro, your problem is almost certainly caused by a bad charge IC. Replace (NOT reheat/reball) U2 on the logic board and this should solve your problem. |
03-12-2015, 15:04 | #4 (permalink) |
Junior Member Join Date: Apr 2008
Member: 747693 Status: Offline Thanks Meter: 5 | Dont listen to this guy, its not always the U2 IC, you need to get the schematics and see if any of the missing components are CRITICAL! if so you need to replace or jump (if possible). |
03-12-2015, 17:24 | #5 (permalink) |
Member: 726059 Status: Offline Thanks Meter: 1 | Thanks that i was thinking to do before, tell me if i'm wrong after having a look on schematics, i must replace C12 and C13 for the other i think i can jump L20 used for one way charge - synch |
03-12-2015, 18:24 | #8 (permalink) |
Member: 747693 Status: Offline Thanks Meter: 5 | haha, yeah change U2 IC, why not waste time and money, changing U2 IC solves all iPhone problems!!!!! lets give good advice!!! ALWAYS CHANGE U2 IC |
The Following User Says Thank You to axiom uk For This Useful Post: |
03-13-2015, 12:21 | #12 (permalink) |
Member: 1648562 Status: Offline Thanks Meter: 5 | These missing components certainly can not cause a battery drain. Battery drain is almost always caused by U2 IC damage. |
The Following User Says Thank You to gjnijenhuis For This Useful Post: |
03-24-2015, 21:33 | #13 (permalink) |
Member: 726059 Status: Offline Thanks Meter: 1 | I remove U2 IC, wait for a new one ordered, does the iPhone can boot without it ? Because since i remove it no boot anymore, normal ? Just expect that i don't damage board white removing U2 Thanks |
