11-01-2014, 15:48 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 695725 Status: Offline Thanks Meter: 4 | iphone 5 cap heres the location of the cap https://imageshack.com/i/pdKkNJyEj |
11-01-2014, 20:51 | #2 (permalink) |
Crazy Poster Join Date: Aug 2005
Member: 175617 Status: Offline Thanks Meter: 20 | hi bro.. I can give some starting point using iphone 5 schematic diagram and component layout diagram C327 is your problem here's the component layout to know where can connect c327 here's schematic diagram to check where can jumper the C327 here's the nearest capacitor c320 and c321 but make sure u know the common ground of capacitor before you make jumper. don't make mistake it's POWER IC.. check battery connector if shorted before put battery or power supply okey? double check your diagram bro I know u can solve it |
The Following User Says Thank You to joicute For This Useful Post: |
11-05-2014, 19:53 | #6 (permalink) |
Crazy Poster Join Date: Jan 2014
Member: 2110377 Status: Offline Thanks Meter: 5 | No, no. no! If you do this, you'll make a short! When you replace C327 you connect one side to ground (the intact side on the pcb) but there's the pad missing at the supply-side, correct? So you make a jumper from the supply-side of C327 to the supply-side of either C320 or C321. Regards, Torsten |
11-06-2014, 10:04 | #8 (permalink) |
Member: 2110377 Status: Offline Thanks Meter: 5 | Have you tried the function without that cap? On 3GS logic board there is no matching cap. You can find 10µF caps there but the package size is different, you need a 402 package and on 3GS they are 603 which means they are bigger. |
