02-17-2015, 08:18 | #31 (permalink) |
Junior Member Join Date: May 2012 Location: FREETOWN SIERRA LEONE Age: 38
Member: 1754955 Status: Offline Sonork: 100.7777 Thanks Meter: 0 | all the links here are not working ,so can some one help me with a link to fix my iphone 5 not charging problem ? regards.. |
02-19-2015, 00:55 | #32 (permalink) |
Junior Member Join Date: Oct 2010 Location: Santiago, Chile
Member: 1418210 Status: Offline Thanks Meter: 8 | Jumping the Q2 is never recommended guys! You can burn your U2, PMU or if someone has really bad luck could ignite your battery and the device explode... Q2 has a reverse gate protection and brings the power source (+5V) to U2 and the PMU IC. This power source is called PP5V0_USB_PROT on iPhone 5/C/s and PP_TRISTAR_PIN on iPhone 6/6 Plus. Before changing the Q2, verify if there is +5V on this line when an original charging cable is connected (connected to power obviously) If PP5V0_USB_PROT is present, you might fix the problem by replacing U2, if not, by changing Q2. Cheers! |
The Following 3 Users Say Thank You to crispain For This Useful Post: |
04-02-2015, 22:08 | #34 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Romania
Member: 467437 Status: Offline Thanks Meter: 31 | i have ... almost the same problem on the iPhone 5, it is charging only from power plug, when connected to PC USB it's not charging and not being seen by PC, i have removed the same USB ic made the double jumper solution as a first try, does anyone knows exactly what is wrong and which would be the good solution ? there are 3 solutions with 3 jumper to be applied over the internet. Phone showing charging but again, only from power adapter, from PC nothing, it is not being seen in DFU as well. |
04-14-2015, 13:20 | #35 (permalink) |
Freak Poster Join Date: Aug 2014
Member: 2242847 Status: Offline Thanks Meter: 5 | whats the easiest way to remove this ic for no charging solution for jumper hi guys today i was trying to revmove this ic for jumper solution for no charge on iphone 5 and i damaged the tracks aswell for the fututre is there any best way to remove this ic plz guid e |
12-23-2015, 02:04 | #44 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2229459 Status: Offline Thanks Meter: 7 | This jumper is working perfect!! Only 3 points if you have damage the tracks. See this pics. You must solder 3 point bridge (red line) |
The Following 3 Users Say Thank You to periquitodel For This Useful Post: |
01-09-2016, 02:53 | #45 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1171722 Status: Offline Thanks Meter: 3 | [QUOTE=periquitodel;11495275]This jumper is working perfect!! Only 3 points if you have damage the tracks. See this pics. el punto que soldaste en medio es un test point ??? regards |
The Following User Says Thank You to alejandrolavin For This Useful Post: |
