Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-02-2013, 03:03   #16 (permalink)
Member: 1478374
Sonork: 55555
Thanks Meter: 2
iphone 5 stoped after use bad charger ???
plezzzz help
not charging i change batarry but not work
Old 12-04-2013, 00:49   #17 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
share picture of burning part of your board.,,,,,,
Old 12-12-2013, 12:35   #18 (permalink)
archon2807's Avatar
Member: 772714
Thanks Meter: 23
my iphone 5 charging but fast drain, i change batt from same iphone batt still fast drain???
Old 01-14-2014, 19:10   #19 (permalink)
Member: 1418896
Sonork: mjd_76_09
Thanks Meter: 3
help me please
help me i damage the board. there is any way to fix the charging please.
Old 01-15-2014, 18:50   #20 (permalink)
Member: 1418896
Sonork: mjd_76_09
Thanks Meter: 3
please tell me what i do how i find the 3 dot.please help.
Old 01-15-2014, 19:45   #21 (permalink)
Member: 1418896
Sonork: mjd_76_09
Thanks Meter: 3
how i pass the ic. i couldnt trace the diagram.
Old 03-13-2014, 17:24   #22 (permalink)
Member: 2147070
I have same problem. iphone 5 does not charge If I turned off it. If I turned on it, I can charge but If battery dies completelly than I cannot turn on anymore or charge. which IC must be replaced? Does jumper solution solve this problem?
Old 04-07-2014, 23:24   #23 (permalink)
Member: 178450
Thanks Meter: 54
same problem with one iphone 5, have some pads lifted. there is any alternative point? can anyone have a good board to measure it?
Old 05-01-2014, 09:26   #24 (permalink)
Member: 2087389
Thanks Meter: 5
same problem need help
Old 05-31-2014, 14:24   #25 (permalink)
Member: 2030552
Hi did you get any solution on the phone 5 charging IC?
Old 08-04-2014, 19:17   #26 (permalink)
Member: 1759455
Thanks Meter: 9
I did, but doesn't work !! any other solution ?
Image herre:
i.*****. com/vN2Vzxd.jpg
(theres a space between the . and the com
Old 08-14-2014, 03:50   #27 (permalink)
Crazy Poster
Member: 2238121
Thanks Meter: 5
I have iPhone 5 I change ic but still is not showing charging symbol pls share guid how can I solve my problem
Old 11-15-2014, 00:02   #28 (permalink)
Registered User
Member: 1164681
Thanks Meter: 15
Hi i have a iPhone 5 that shows me the symbol of charge but nothing, no charge nothing, i read this post but nobody said wich solution works... little help please???
Old 11-17-2014, 11:01   #29 (permalink)
Crazy Poster
Member: 2110377
Thanks Meter: 5
The problem is U2 IC. Search forum for U2 IC and you will get lot of information.
Old 01-14-2015, 10:45   #30 (permalink)
Member: 208895
Thanks Meter: 6
I pnhone 5s charging way ?
The Following User Says Thank You to bhrphone For This Useful Post:
Page generated in 0.29471 seconds with 8 queries
