Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-17-2015, 08:18   #31 (permalink)
Member: 1754955
Sonork: 100.7777
hi
all the links here are not working ,so can some one help me with a link to fix my iphone 5 not charging problem ?
regards..
Old 02-19-2015, 00:55   #32 (permalink)
Member: 1418210
Thanks Meter: 8
Jumping the Q2 is never recommended guys! You can burn your U2, PMU or if someone has really bad luck could ignite your battery and the device explode...
Q2 has a reverse gate protection and brings the power source (+5V) to U2 and the PMU IC.
This power source is called PP5V0_USB_PROT on iPhone 5/C/s and PP_TRISTAR_PIN on iPhone 6/6 Plus.
Before changing the Q2, verify if there is +5V on this line when an original charging cable is connected (connected to power obviously)
If PP5V0_USB_PROT is present, you might fix the problem by replacing U2, if not, by changing Q2.
Cheers!
The Following 3 Users Say Thank You to crispain For This Useful Post:
Old 02-19-2015, 19:55   #33 (permalink)
Member: 726059
Originally Posted by mjd_76_09 View Post
help me i damage the board. there is any way to fix the charging please.
Same problem now, while removing Q2, now no charge anymore even off and no synchro, too bad ..
Can wa find alternative point to make the jumper ?
Thanks
Old 04-02-2015, 22:08   #34 (permalink)
fricosu007's Avatar
Member: 467437
Thanks Meter: 31
i have ... almost the same problem on the iPhone 5, it is charging only from power plug, when connected to PC USB it's not charging and not being seen by PC, i have removed the same USB ic made the double jumper solution as a first try, does anyone knows exactly what is wrong and which would be the good solution ? there are 3 solutions with 3 jumper to be applied over the internet. Phone showing charging but again, only from power adapter, from PC nothing, it is not being seen in DFU as well.
Old 04-14-2015, 13:20   #35 (permalink)
Member: 2242847
Thanks Meter: 5
whats the easiest way to remove this ic for no charging solution for jumper
hi
guys today i was trying to revmove this ic for jumper solution for no charge on iphone 5 and i damaged the tracks aswell for the fututre is there any best way to remove this ic plz guid e
Old 04-14-2015, 13:33   #36 (permalink)
Member: 726059
Same hère for deffective Track, looking for alternative Track
Old 05-16-2015, 15:00   #37 (permalink)
Member: 2243030
Sonork: 1640811
Thanks Meter: 28
Originally Posted by my_sistemas View Post
this solution work!
but i cant see the solution
please tell me. black solution, yellow solution, red solution or green solution???
Thank you!
yes solution best successfuly
The Following User Says Thank You to habib121 For This Useful Post:
Old 05-27-2015, 10:37   #38 (permalink)
Member: 663082
Thanks Meter: 12
I have Iphone 5s it not showing charging symboll and not full bettery I have also change the complete charging streep
Bro any solution
Old 06-10-2015, 06:11   #39 (permalink)
Member: 2176571
Thanks Meter: 4
iphone 5c charging solution ???????? anybody have
Old 07-07-2015, 06:23   #40 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 228
Originally Posted by d-Artigo View Post
iphone 5 schematics diagram .. .DOWNLOAD
Link is damage
Old 09-27-2015, 16:32   #41 (permalink)
Member: 1804228
Sonork: 0097334471454
iphone 5c fake charging. please help me. charging time automatic restart.
Old 09-27-2015, 18:00   #42 (permalink)
Member: 1804228
anybody please help me.................
Old 11-11-2015, 13:00   #43 (permalink)
Member: 1922125
Sonork: vic69
Ole Cris! nice knowledge you have on iphone!!
The Following User Says Thank You to vic69 For This Useful Post:
Old 12-23-2015, 02:04   #44 (permalink)
Member: 2229459
Thanks Meter: 7
This jumper is working perfect!! Only 3 points if you have damage the tracks. See this pics.
You must solder 3 point bridge (red line)
The Following 3 Users Say Thank You to periquitodel For This Useful Post:
Old 01-09-2016, 02:53   #45 (permalink)
Member: 1171722
Thanks Meter: 3
[QUOTE=periquitodel;11495275]This jumper is working perfect!! Only 3 points if you have damage the tracks. See this pics.
el punto que soldaste en medio es un test point ???
regards
The Following User Says Thank You to alejandrolavin For This Useful Post:
Page generated in 0.34889 seconds with 8 queries
