Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-30-2015, 04:37   #1 (permalink)
Member: 120173
Thanks Meter: 11
iPhone 5 Couple of Vertical lines on screen
I've checked under a microscope. All pins look good and fine. Phone is not water damaged. I've already tried few screen and same result. also have tried many battery. i dont think it has got to do with battery anyway.
sometime the lines disappear.
bad chip somewhere?
see photos
Old 11-30-2015, 08:00   #2 (permalink)
Member: 656426
Thanks Meter: 2
did you have change the screen???
Old 11-30-2015, 11:27   #3 (permalink)
Member: 120173
Thanks Meter: 11
Hi, i bought the phone without a screen.
Old 11-30-2015, 16:45   #4 (permalink)
Member: 2487344
Trying adding a small bit of pressure (very delicately) to the lcd connector and checking the display then, this issue can be a chip issue though but generally I've found a mildy loosely mounted connection pin to be the issue and a small bit of pressure can solve it. Hope this helps.
Old 11-30-2015, 20:34   #5 (permalink)
Shahin Hasan's Avatar
Member: 1529244
Sonork: 1720
Thanks Meter: 150
bad chip somewhere?
see photos
First Replace screen it not solve then check carefully lcd and touch connector may have dust inside.
Old 12-04-2015, 01:50   #6 (permalink)
Member: 120173
Thanks Meter: 11
board is fixed. i've replaced the LCD FPC connector.
Page generated in 0.15754 seconds with 10 queries
