04-14-2015, 16:21 | #1 (permalink) |
Junior Member Join Date: Jan 2009
Member: 943277 Status: Offline Thanks Meter: 5 | iPhone 5 dead Doesn't power up, doesn't charge and doesn't sync. When the charger cable is plugged in, seems there is a bit of heat just above the CPU. I didn't take the metal shielding off as i left my hot gun at home. I also put the volt meter on the battery terminals while the charger was in and i didn't get any voltage readings. Is there anything else i should check, or just go ahead and change the U2 IC? If i get a fully charged battery from another iphone 5 will the phone come on even if the u2 ic is faulty? Or will nothing happen until i swap out u2 ic. Many thanks in advance |
04-14-2015, 18:25 | #2 (permalink) |
Member: 943277 Status: Offline Thanks Meter: 5 | So i put a new battery in. Still didn't come on. Took the shielding off and discovered a nice bit of water damage. Gave it a bath of isopropyl and a wee scrub. Back out bath and let it dry. Iphone back together but still nothing. Got it back in the bath soaking. I put the microscope on it to check for missing componates but need the schematics to double check stuff. Anything I can do? Thanks |
