04-08-2014, 21:53 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Inside Philippines Age: 40
Member: 860600 Status: Offline Sonork: 100.1659487 Thanks Meter: 38 | iPhone 5 Fast Drain Battery, Unit Goes Hot no Short at all. Model Iphone 5 Problem: Unit Goes Hot , Fast Drain Battery , If The Battery is Drain, Unit will not power On Even you Charge for how many Hoours. 1st Action Taken [Basic Step not direct to Hardware]: Check the board if SHorted, but all is clean no short at all, Try to Replace new Charging COnnector and Battery Sad to say FAILED. 2nd Action Taken = Hardware Method. Trying to Replace new U2 IC. Result After Replacing U2 ic = All is Well, The Test the Unit watching youtube till battery is Drain. then i charge. works like a charm. its Normal charging now no Heat at all. Problem Solve |
The Following User Says Thank You to jovey_laput For This Useful Post: |
04-30-2014, 22:24 | #3 (permalink) |
Freak Poster Join Date: May 2012 Location: dubai Age: 38
Member: 1766383 Status: Offline Sonork: [email protected] Thanks Meter: 4 | Yas grate job but very care fully smol mistack mobil is dead like over hateing and under u2 ic on pcb pin damge be care fully every one |
