LCD Refurbish All things related to LCD / Screen refurbish and repair |
03-24-2015, 05:24 | #47 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1406622 Status: Offline Thanks Meter: 0 | sometime i feel loca glue is not good for repair loca always turn yellow in a few days . i did try many many screen using loca . i think almost 50% will turn yellow . finally i guess the problem is my uv light is not power enough . do not use 36W nails uv .. thats nothing to use .. the light bulb so suck . after use a month , u have to replace new bulb /////////////////////whatever the bulb still light on .. thats cannot fully cure the glue .. some of glue didnt dry very well . thats why a few days it will turn yellow and damaged the screen . i try to cure same screen in different days .Around 5 days later if the lcd didn't turn yellow . then i install to THE phone . that will more safe .. i m going to purchase the led uv that sell on ebay for $89 that one . it seem super bright . i think that one is good to cure loca glue . i also purchased oca film let see which one is prefect for repair screen . sorry for bad engish . hope my experience can help you .. |
01-26-2017, 15:17 | #49 (permalink) | |
Junior Member Join Date: Feb 2014 Location: peshawar kpk pakistan Age: 54
Member: 2135622 Status: Offline Thanks Meter: 0 | Anyone? I'm having the same problem. The OCA liquid keeps seeping into the backlight Quote:
hi gently use petrol on the glue if possible put a small piece of cloth on glued lcd and then put petrol on the cloth. after one or two minutes replace the cloth and gently remove glue with finger. if any one have problem then message me | |
