03-06-2014, 09:13 | #94 (permalink) |
Freak Poster Join Date: Jul 2009 Location: ksa
Member: 1081268 Status: Offline Thanks Meter: 73 | iphone 5 not turning on or charging but charging warning is coming in low battery I put full charged battery but not power up........ And not coming any warning in display Pease help me.................... |
03-07-2014, 11:17 | #95 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | Connect to iTunes solution Hi ! here one of the possible solutions if you get the message "connect to itunes" when you power on your iphone5. Last day, i received an iphone5 with this message. Some components was damaged from the previous owner. I have discovered that if U3 doesn't get power through R20 or R22, the "connect to itunes" message appear. After soldering back a new resistor, phone is working again perfectly, without need to restore HT1808--connect_to_itunes-001-en.png Here my solution, it is one of many things that can happen : iphone5 connect to itunes solution.png |
04-08-2014, 10:56 | #98 (permalink) |
Freak Poster Join Date: Sep 2007 Location: laguna
Member: 580947 Status: Offline Thanks Meter: 7 | good day brothers.. can someone give me an idea for iphone5.. i tried battery with charged it powers up working all functions.. problem is when you connect to charger it appears "this accessory may not be supported," even on laptop or desktop but i can sync my apps or download songs from pc to my iphone 5.. it means the problem was the charging was not working.. history i left my iphone plug in charger for 2hours.. pls.. any idea brothers thankyou.. |
04-09-2014, 14:21 | #99 (permalink) | |
Member: 1873863 Status: Offline Thanks Meter: 67 | Quote:
This is know to happen with chinese copy charger and cables.. | |
04-18-2014, 16:06 | #100 (permalink) |
Junior Member Join Date: Jan 2007
Member: 442057 Status: Offline Thanks Meter: 3 | iphone 5 getting hot Iphone 5 getting really hot and drains the battery. when the battery drains it wont charge back up. I have to take out the battery and charge it. need help asap. |
04-20-2014, 11:41 | #101 (permalink) |
Freak Poster Join Date: Apr 2007 Location: saudi arabia
Member: 498134 Status: Offline Thanks Meter: 26 | iphone 5 rear microphone does n't working i phone 5 rear mic not working , mic already change still problem this phone also water damage any body can found mic ic |
04-22-2014, 11:56 | #103 (permalink) |
Junior Member Join Date: Apr 2014 Location: Scotland
Member: 2172736 Status: Offline Thanks Meter: 0 | Nothing comes on, no sign of life in it. Tried: - Hard reset ( home + power buttons) - Holding the home button while connecting the data cable. - Checked the connectors are popped in. - Tried to connect it to itunes with the battery disconnected. -left it to charge on mains for 24h. Nothing worked. Any ideas? |
