10-27-2015, 04:58 | #136 (permalink) |
No Life Poster Join Date: Jun 2006 Location: CANADA
Member: 292789 Status: Offline Thanks Meter: 636 | FL26 IS FOR LCD BACK LIGHT IF YOUR LCD BACKLIGHT HAVE NO ISSUE THEN NO NEED TO SHORT FL26. FOR gyroskope, motion sensor, compas CHECK U16 MAYBE NEED TO CHECNGE |
The Following User Says Thank You to ansari123 For This Useful Post: |
01-16-2016, 10:06 | #139 (permalink) | |
Insane Poster Join Date: Apr 2012
Member: 1742810 Status: Offline Thanks Meter: 7 | touchscreen doesnt work Quote:
The Following User Says Thank You to pentium7 For This Useful Post: |
02-15-2016, 17:50 | #141 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2308898 Status: Offline Thanks Meter: 0 | Hi, My iPhone 5 have greyed out Wifi, it have a whater damaged, i have change over Blutetooth/Wifi Modul a capacitor and rehot the Bluetooth/Wifi Modul but have same problem. Have anyone a picture solution ?? pls help. gr |
04-03-2016, 22:53 | #143 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Quote:
Solution is: Check C149 and C156 if they give a short to ground. If so, Remove or replace the caps. Your touchscreen will work again. Ps. Never reheat a glued ic. The balls under the ic will pop and jump like popcorn and created a shortcut. | |
05-05-2016, 12:00 | #145 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2546939 Status: Offline Sonork: Damian Thanks Meter: 0 | hi i have a iphone 5 water damage i desold the shields and clean it with alcohol and put a new batter when whitch on the phone show the apple for 10 15 seconds and tun off, i i put dfu mode is ok, start restoring but have error (-1) any idea ? |
04-25-2017, 07:10 | #147 (permalink) |
Junior Member Join Date: Dec 2013 Location: mindanao
Member: 2077005 Status: Offline Sonork: [email protected] Thanks Meter: 0 | thanks a lot sir.... |
06-23-2017, 15:08 | #148 (permalink) |
Insane Poster Join Date: Mar 2016 Location: Brazil Age: 30
Member: 2553311 Status: Offline Thanks Meter: 6 | iPhone 5 rebooting after 2 or 3 seconds of the apple logo screen constantly, battery ok, the reboot persists even everything disconnected but the screen from the board, tested with a power supply and it doesn't show high energy draining, any solution or where to start looking? It is NOT water damage. Thanks! |
07-25-2017, 22:34 | #149 (permalink) |
Freak Poster Join Date: Oct 2003 Location: London Age: 46
Member: 42036 Status: Offline Thanks Meter: 6 | Iphone 5 no display with any copy screen. Hello there, got 1 iphone 5 was water damaged, after full clean, have display with the old broken screen but touch not working and can see light square box in the background display, tried a few copy screen, no display but can see the light from the back of the screen, tried another original screen, have display but also touch not working, urgently need some help, thanks a lot. |
The Following User Says Thank You to mobile_2003 For This Useful Post: |
08-20-2019, 23:29 | #150 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Telegram Aceunlock
Member: 549784 Status: Offline Thanks Meter: 167 | I have an iPhone 5 which connects all fine to pc, you can backup hear incoming calls however the screen is blank. I have tried a new screen but didnt solve the issue. Any ideas what it could be ? BR E_H |
