08-12-2013, 14:42 | #50 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 321752 Status: Offline Thanks Meter: 28 | no imei no baseband Hi , after replacing iphone 5 battery it shows no imei no medem firmware.so i do erase all the settings,no it stuch on activation screen shows on top searching.when i checked the motherboard i found one crysTal chip edge has been broken near to sim tray located.any solution to fix this issue |
09-05-2013, 13:09 | #53 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 883061 Status: Offline Sonork: messts shade Thanks Meter: 0 | Photo0026 - HostingPics.net - Hébergement d'images gratuit friends iphone 5 touch screen not working i found this ic broken any solution thnx in advance |
09-16-2013, 21:18 | #54 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2006595 Status: Offline Thanks Meter: 0 | Hello, After cleaning up an old water damaged iphone 5 the touch screen stopped working after a week where everything on the phone worked. I have checked all connections on the connector and they are fine. I have checked the two supply voltages for U14 they are also fine 5,7V and 1,8V. When checking U12 (touch controller) the supply voltage measured on C372 should be 1.8V (PP1V8_GRAPE) but is always 0V. The 5.1V (PP5V1_GRAPE_VDDH) supply to U12 measured on C369 is 0.038V. I have tried to heat up the U12 with 320 C for 25 sec, no change. I guess there is a short somewhere, but cant find it / mesasure it. I measured 280 ohm over the C372 capacitor on a working iphone, but on the broken one there was infinite ohm, so maybe it is a lose connection to the U7 power chip? What do you think? |
09-16-2013, 21:30 | #55 (permalink) | |
Member: 2006595 Status: Offline Thanks Meter: 0 | Quote:
Also check the connector J4 for the touchscreen maybe you have a bad soldered pin. | |
09-21-2013, 19:56 | #57 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Canary islands Age: 53
Member: 1332831 Status: Offline Thanks Meter: 7 | Hi Mr wites, i hope you remember me, the man from Canary islands!!! i am fighting with an iphone 5, do not know the history of thus phone, it seems to be ok, no eater damage, when you put a new battery it gets hot in 3 minutes and show the apple, it is possible to restore out, but receive an error "it was not possible to connect to the apple store", it is an strange error, anf it is impossible to activate it, another thong is that the battery drains quickly and do not work more at all, if i put a new battery the phone swicht on and connect to iTunes, but receive the error i mentioned, after a while the battery is dead, and stuck on "connect to iTunes" and impossible to restore (error 2001), and only is possible to swicth on connected to a charger, it seems that the phone is killing the batteries. any idea where to look?? thanks in advance. |
09-26-2013, 07:55 | #58 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 194873 Status: Offline Thanks Meter: 4 | Dear Mate, I am mohammed from tamilnadu india. I have iphone 5 which had a water complaint and screen was replaced with new one.... Now display is ok....But sometimes some applications are wutomatically opens. so if i play games it automaticaly works without pressing.....please give me suggestion on what to do? |
