07-13-2014, 22:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1952487 Status: Offline Thanks Meter: 43 | iphone 5 low volume mic after frame replacemtn! i tested 4 different charging flex cables (with this mic) and still the same, i also put the black rubber on mic and also put the small plastic, nothing helps ! but one i take used original frame and check it there it works great, when i take the flex from the used original frame and put it in my high copy frame problem is the same, it's driving me crazy !! what do i miss ?! |
07-14-2014, 10:46 | #2 (permalink) |
Member: 1952487 Status: Offline Thanks Meter: 43 | Hi, I disconnected all other flex cables and left only the charging port connected. I tested it on skype call and it works good, but on calls not good.. Any solution? Please help!!! |
07-15-2014, 18:21 | #3 (permalink) |
Member: 1952487 Status: Offline Thanks Meter: 43 | Hello, I have found solution.. I don't know why but after disconnecting the power flex people hear me perfectly but when I connect again the power flex people hear me not Good.. I tried to replace the power flex but it doesn't help, any solution ? |
07-15-2014, 19:53 | #4 (permalink) |
Junior Member Join Date: Feb 2013 Location: Greece
Member: 1889335 Status: Offline Thanks Meter: 0 | Hi iphone 5 has three mic maybe you have a conflict.When you assempled the housing did you fit the rubber in the back camera mic?If you take a photo with flash the photo has strange colors?Also try the front camera mic disconnect it and try. |
12-10-2014, 22:15 | #8 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 408358 Status: Offline Thanks Meter: 42 | bro.... try to replace power flex (with up microphone on this and volum buttons) .... If you changed the frame , probably you changed and flexs ... Try to add new flex( ORIGINAL ) .... and will work 100% |
04-18-2016, 14:38 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Albania -Durres
Member: 154346 Status: Offline Thanks Meter: 37 | i have same problem and i changed power buton flex but same problem when conect power buton flex mic have low voice and when disconect power buton flex mic work ok. anyone have solution for this strange ptroblem? thanks |
