Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-20-2014, 17:46   #1 (permalink)
Member: 2088670
Thanks Meter: 6
iPhone 5 low wifi signal
Hi to all, i've an iPhone 5 with a low wifi signal compared to another ones, sometimes it doesn't find any network. Could be a wifi antenna issue? How could i fix this issue?
Thank you in advance
Old 07-22-2014, 20:23   #2 (permalink)
Member: 2088670
Thanks Meter: 6
No one has suggestions?
Old 07-22-2014, 20:52   #3 (permalink)
bod
Member: 16490
Sonork: 100.1621293
Thanks Meter: 908
Check the Murata diplexer
Old 07-27-2014, 00:25   #4 (permalink)
Member: 1961124
Thanks Meter: 3
poor wifi reception could be diplexer but most likely not. first check those two antennae coax cables that run up the left side of board. make sure they are plugged in to two top and bottom coax connectors. next , check that the board is hooked to the main coax connector up top reverse side. and third make sure the two screws up top are inserted ithrough the antanne gold screw holes and into the chassis of the case. if the antennae are missing, (ripped from logic board) you must replace them otherwise you will have poor reception.
Many technician that repair phone leave this unplugged and have poor reception wifi circuitry
Page generated in 0.13626 seconds with 8 queries
