11-20-2014, 05:13 | #1 (permalink) |
Insane Poster Join Date: Aug 2014 Location: Australia
Member: 2249587 Status: Offline Thanks Meter: 11 | iPhone 5 no display, help identify missing components I noticed there are parts missing near the battery connector, looks like the fool has damaged them while changing the battery. I would like to know if the missing parts are related to the screen not working, and also what is the recommended action? Do they need to be replaced, or can I do a bodge and just solder link some or all of them? Note: The half fallen off one is now completely gone after cleaning. So its 4 missing parts now. |
11-20-2014, 13:07 | #2 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Italia
Member: 2044491 Status: Offline Thanks Meter: 18 | take these parts from another bad motherboard and solder them.. your phone reboot for this reason.. because He "doesn't see" the battery.. After if problem of screen will be present, if itunes will found your iphone you will have to check accuracy another area for screen problem.. |
The Following User Says Thank You to Mattia_sp For This Useful Post: |
11-21-2014, 13:35 | #5 (permalink) |
Member: 2249587 Status: Offline Thanks Meter: 11 | I'm good at soldering, just not at this tiny scale. I'm using an WEP 853D and having difficulty getting the solder to ball on the tip of the iron. Any recommendations on a method that will get the job done? |
11-22-2014, 00:28 | #7 (permalink) |
Member: 2249587 Status: Offline Thanks Meter: 11 | I managed to solder links, and still no screen. The phone still comes up in iTunes telling me to respond on the phone to "Trust xxx xxx's iPhone" on the computer (which I can't do with no display) and it vibrates every few seconds until I unplug the cord. I don't know if it is rebooting or has fully booted at this stage. |
11-22-2014, 04:47 | #9 (permalink) | |
Junior Member Join Date: Aug 2013 Location: Antwerpen Belguim
Member: 1996614 Status: Offline Thanks Meter: 2 | Quote:
Have you checked If the connectors on the board are good ? I yes then it could be that the touch controller ic needs looking in to or just needs a reball. I had the same problem with a iphone 4s until i changed the touch controller ic Now working great . Thats maybe something to look in to no ?? Ok you'll find it !! Maybe it wil take some time but you wil | |
11-25-2014, 13:04 | #11 (permalink) |
Member: 2249587 Status: Offline Thanks Meter: 11 | Job done! L41 and L42 replaced... well bodged up (note L41 & L42 are 2 separate parts in one), but it's working. In summary, the previous owner probably had a mishap with a broken screen or while replacing it and burned out multiple fusible links. My repair is a bit rubbish and possibly dangerous if it ever develops a short somewhere. |
