Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-18-2014, 20:43   #1 (permalink)
Member: 1536098
Thanks Meter: 4
iPhone 5 No Loudspeaker
1) I have an iPhone 5 that was slightly water damaged
2) EVERYTHING ELSE WORKS except for the sound from the LOUDSPEAKER
3) I noticed 1 bad CAPACITOR around the AUDIO CODEC U21
I have not removed it because I think that it will not solve the issue.
C422
[IMG][/IMG]
4) I checked for continuity from C360 to pin 29 on the J7 connector
and from R123 to pin 28 on the J7 connector (J7 = dock connector plug)
both lines checked out fine
[IMG][/IMG]
5) I checked all the neccessary voltage values all checked out just about
right.
6) EVERYTHING ELSE WORKS (microphone works, earpiece speaker works
headphones work etch)
7) I have also restored the phone succesfully but no sound
8) If I put my ear to the LOUDSPEAKER when listining to music I can
hear a rustling noise like elcrtons are traveling.
So I believe U19 the speaker apmlifier IC is working.
WHAT SHOULD I DO
Old 12-18-2014, 23:19   #2 (permalink)
Member: 1873863
Thanks Meter: 67
Have you tried the simpler solution ?
...Changing the loudspeaker ?
Old 12-18-2014, 23:31   #3 (permalink)
Member: 1536098
Thanks Meter: 4
Yes I have changed the loudspeaker 3 times in working phones.
Old 12-19-2014, 07:54   #4 (permalink)
Member: 1536098
Thanks Meter: 4
Anyone else have any information
Old 12-19-2014, 09:24   #5 (permalink)
shanoopc's Avatar
Member: 1180290
Sonork: 100.1652502
Thanks Meter: 73
iphone 5 ringer
check ringer on settings . if working on settings,
change h/f flex(also check detection path capacitor)
if not ok, reball/ change the u19 + u21 one by one
Old 12-19-2014, 20:55   #6 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,594
Try replace corroded cap in your pic also look for other maybe corroded and have short or low readings.
Old 12-20-2014, 22:29   #7 (permalink)
Member: 1536098
Thanks Meter: 4
I replaced the cap nothing happened.
I had to reball U19 and U21
Page generated in 0.14911 seconds with 8 queries
