09-01-2014, 11:38 | #16 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | maybe baseband problem |
The Following User Says Thank You to BesfortShalaTec For This Useful Post: |
09-01-2014, 15:56 | #17 (permalink) |
Junior Member Join Date: Oct 2005 Location: GSM world
Member: 191786 Status: Offline Thanks Meter: 1 | All ok, imei, wi-fi adress modem firmware all ok, first stay in "searching" for 30 seconds an then no service. At Carrier in info see the Network Operator. Thx. |
03-29-2015, 18:50 | #22 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2262395 Status: Offline Thanks Meter: 0 | hey brow its not about the charging port, iphone will showing the searching mode every time you pull off hte battery, its normal. after you change the battery also. so restart yout iphone maybe 3 times after that you will see the signal. some times you see that "searching" or "searching...3G/4G" mode but if you call that number you can receipt that incoming calls and text also. its software effect. try to restart 3-5 times after that you can try reset network setting.. Good luck *some cases you broke the component while opening the boards, maybe. always using antistatic strap while you work on it. |
