08-30-2014, 10:44 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Iphone 5 PMIC tracks missing....... When i tested the Battery connector i found out that the Battery_ntc supply was short to gnd..... I removed all the caps on this line but still the supply is short..... so i removed the PMIC as the supply is directly going in it..... But to my Surprise ..... the Battery_ntc is still short even after all the components including the PMIC is removed...... But ive got one more problem now ...... While removing the PMIC i lost lots of tracks..... Can anyone tell me if this job could still be saved ? Are some of those tracks NC ? I know some of the tracks can be repaired as the source is near the ball ........ |
08-30-2014, 13:29 | #2 (permalink) |
Junior Member Join Date: Mar 2008
Member: 720679 Status: Offline Thanks Meter: 1 | Yes, it can be repaired, use a very small wire smaller then 0.1mm. All the pads that have the via around it must be repaired. The pads without are mostly non connected/used pads. Check for a copper dot in the pcb mask to see if it is connectted. I had to do the same with an iphone 4s. It takes a lot of time and patience actually |
The Following User Says Thank You to best4free For This Useful Post: |
09-01-2014, 15:15 | #3 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Italia
Member: 2044491 Status: Offline Thanks Meter: 18 | you should do a procedure like this.. https://www.youtube.com/watch?v=BPdQcTpUjyI |
The Following User Says Thank You to Mattia_sp For This Useful Post: |
